Results 1 to 8 of 8
Thread: 200x lost spark
    Mar 2013
    Minnesota
    441
    200x lost spark
    so today i decided to check my timing chain, so i opened the spot that has (cdi) on it on the head and took everything off to check the timing chain. timing chain was ok so i put everything back and closed it up tried to start the trike and it has no spark now. Im still new to this so i need some help, what did i do to make it lose spark? thanks for your help and happy thanksgiving
    ~~ATC's Currently Owned~~
    1983 Honda 200x - Main ATC
    1985 Honda 200x - Parts Bike
    ~~ATC's Previously Owned~~
    1983 Honda 250R
    1984 Honda 200X
    1979 Honda 110
    1983 Honda 125M
    1984 Honda 200
    1983 Kawasaki klt 200a
    1986 Honda 200s
    ~~Other Toys Owned~~
    2012 Pro R 800
    1993 Polaris Indy 500
    2004 Yamaha 125
    1990 Thunder Kart - 250CC
    2001 Yamaha Blaster - 240kit, aftermarket exhaust, power reeds
    kebby28's Avatar
    Nov 2012
    Antrim, NH
    435
    Did you plug the two wires back in? Did you mark the position of the rectifier/ advancer? Did the keyway fall out? Maybe you pulled a wire off the coil by accident. Try taking a pic and posting it here.
    Mar 2013
    Wausau, WI
    147
    Yep definatly check and see if the pin is still it falls out very easily
    Mar 2013
    Minnesota
    441
    1983 Honda 250R
    1984 Honda 200X
    1979 Honda 110
    1983 Honda 125M
    1984 Honda 200
    1986 Honda 200s
    2012 Pro R 800
    2004 Yamaha 125
    Slidell, LA
    4,738
    see that black box? it has to be set with a feeler gauge, so check your manual and make sure it is set correctly. Also, that piece is magnetized, so make sure you set the gap correctly. The same thing happened to me when I rebuilt my last motor. My feeler gauge felt perfect, what I didn't know was it was sticking to the magnet side and my spark was weak or sometimes non-existent.
    Mar 2013
    Minnesota
    441
    ok i aligned everythingto spec in the manual. now im at the plate with the black box. i dont see anything on aligning it how do i do it?
    1983 Honda 250R
    1984 Honda 200X
    1979 Honda 110
    1983 Honda 125M
    1984 Honda 200
    1986 Honda 200s
    2012 Pro R 800
    2004 Yamaha 125
    Mar 2013
    Minnesota
    441
    any ideas?
    1983 Honda 250R
    1984 Honda 200X
    1979 Honda 110
    1983 Honda 125M
    1984 Honda 200
    1986 Honda 200s
    2012 Pro R 800
    2004 Yamaha 125
    Slidell, LA
    4,738
    Sites been down all day. This is from the manual.
Name:	Pulse Air Gap Setting.jpg
