Properly functioning forks don’t fully extend unless your front wheel is off the ground and even then there is a small spring in each fork that prevents it from fully extending otherwise they would make a loud clunk every time you lifted the front wheel, but in your case the amount of sag you have means nothing because your forks aren’t working properly. If you want help with this and setting up your suspension you need to indicate if these are going to be replaced with inverts or rebuilt.
