Results 1 to 15 of 20
Thread: TRI Z front wheel on a 225DX?
    Nov 2013
    Oxford CT, New Haven County
    984
    Will a TRI Z front wheel work on a 225 DX front end? will there be any good reason to do this? the breaks will be something to think
    about but will the wheel fit up no problems...like Axel size or tire size?
    Jun 2012
    Aberdeen WA USA
    139
    The 225 has drum brakes and the tri z has a disk I think you need to use the tri z shocks and brakes to make it work IIRC.
    Jun 2012
    Aberdeen WA USA
    139
    You might be able to use the 4 lug front hubs from the later model ytm225 I'm not sure I can't seem to find the bolt pattern specs for the tri z and all my 225's use the 3 on 100 rims so I can't compare.
    Nov 2013
    984
    so the axle size of the tri z wont fit the YTM 225 forks? does anyone know, are the tri z forks longer? will they fit into the YTM front end or do I need to switch out and use the whole front end of the tri z? I love the way the tri Z sits.
    Mar 2013
    Central PA
    2,362
    225dx with Tri-Z front end and modified rear end. Its a members on here, very interesting build. The best looking dx you will see, and i think it was for his wife! Maybe someone will remember whos it is, i just saved it because it looked awesome.
    Sarnia, Ontario, Canada
    3,415
    That 225DX is having a serious identity crisis Ghost..it's kinda tripping me out!!
    Got a pic of the rear axle?? I have to see how you got that disk system setup.
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Mar 2013
    Central PA
    2,362
    Im not sure if there was a detailed build thread of not. But i saw it once, forgot about it. Then someone brought it up again and then i saved the picture so i wouldnt forget about it. Ill try to search for it tonight or dig up some more details. It got me curious too because as we all know it was originally drum breaks. And then i thought it was a rear end from something else. But then again its shaft driven.
    Maybe someone will see that and say oh yea, thats mine.
    Or know whos it is.
    Big Mike's Avatar
    Hanson, MA
    1,062
    it belongs to Derrick Adams
    Oct 2012
    Somerset County PA
    720
    I did the conversion on my dx, the best thing to do is just get a whole tri z front end, and yes the tri z forks are ALOT bigger/taller than the dx it will make it stand up like 3-4 inches maybe more! But if you do the front end swap you have to do some modification to it, for it to fit in good
    Quote Originally Posted by Howdy View Post
    Yea, looked like a monkey ******* a football. LMAO
    Howdy
    Currently Own-
    84 250R My Baby/Project
    83 Yamaha 225dx
    79 Honda Twinstar - Big Ole Turd
    Heres My Feedback Page
    http://www.3wheelerworld.com/showthr...for-ColtonGG33
    glendive, montana
    1,822
    actually the rear brakes on a ytm 200, or 225 are disk they are just enclosed in a housing
    Jul 2012
    Grand Rapids, MI
    997
    I have seen it in person, very nice rider. I believe Derrick heavily modified the swing arm and used a shock from another machine. There is a thread on it here.
    1984 ATC 200XR
    1984 ATC 300R
    1983 ATC 88
    Feedback for Mike Pargiello
    Oct 2012
    Somerset County PA
    720
    If I remember correctly he welded another shaft to it to extend it, I think he put wheel spacers on it, and used a raptor shock, I'll see if I can find the thread he had for it
    Howdy
    Currently Own-
    83 Yamaha 225dx
    New2Tri-Z's Avatar
    New2Tri-Z is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2012
    Redding, CA
    380
    It is Derrick bike, he doesnt diclose too much of the mod in the thread but by far a prettyy sweet trike.
    http://www.3wheelerworld.com/showthr...rs-and-running
    Currently Owned
    1986 Yamaha Tri-Z 350???
    1985 Honda ATC 70
    1985 Honda ATC 250R
    2006 Suzuki LTR450
    2005 Suzuki LTZ400
    2005 Polaris Predator 50
    2004 Polaris Predator 90
    2-Honda Trail 90's (need to be brought back)
    Feedback Thread http://www.3wheelerworld.com/showthr...-for-New2Tri-Z
    Nov 2013
    984
    At what point does it become easier to just buy a TRI Z and put your YTM plastics on it? lol
    So... using my YTM front forks, will the tri Z front wheel (With axle) work or will the Axle not fit the holes in the forks?
    glendive, montana
    1,822
    I would check for you but it is way to cold here for me to be tinkering in the yard we are -12 deg outside
