Results 1 to 11 of 11
Thread: 350x front fork on 250sx
    Nov 2011
    Connecticut, USA
    50
    Is it possible to use a 350x front suspension on a 250sx frame? Would like to run it both for its improved suspension and its disc brake.
    1981 Honda 185s
    1982 Honda 110 (junker under a tarp for now)
    1983 Honda BIGRED-185s Hybrid
    1985 Honda BIGRED 250ES
    1985 Honda 250sx
    1983 Kawasaki KLT250a
    Oct 2008
    Reedsport Oregon
    856
    may have to mod the trips not sure on that i know 350x bolts right on 200x.
    id go 82- 250r the shocks are way better than sx, cheaper, you get a disc and keep the fatty tire best of all
    Jan 2011
    Choctaw, OK
    2,755
    The 350X front end is a direct bolt on and the triples fit with no problems however, you have to fabricate and weld on a steering stop to the front of the SX frame neck. You also have to run the forks up in the triples about 1.5" to get the ride height right. The 200X forks also bolt up but the basic fork is not much better than the stock SX forks but you do get the benefit of the hydraulic brake. The 350X forks do change the rake angle just a tad because you would be going from trailing axle to a leading axle. I have don't a couple of SXs with the 350X front end.
    Attached Thumbnails Attached Thumbnails Breakin the Law [1024x768].JPG   100_0611 (Copy).JPG
    Nov 2011
    Connecticut, USA
    50
    FlyingW; your trike.... WOW. I'm about to start building a 1985 from the frame up. I have no forks so I was definitely wanting to use 350x forks. Thanks for all the info. If you have a chance, do you think you could take a picture of the frame stop fab? Appreciate it.
    1981 Honda 185s
    1985 Honda 250sx
    Jan 2011
    Choctaw, OK
    2,755
    Send me your mailing address and I'll send you one. I cut some out at work on the waterjet and I have a couple left. It gets welded dead center about 1/2" up from the bottom.
    Jan 2011
    Choctaw, OK
    2,755
    When installing the stop, I would suggest installing the triples and tack the fork tubes in the triples. Set the gas tank on the frame in its installed position. Now you can fine align the stop so the fork tubes swing equally on both sides and the fork tubes clear the tank equally on both sides. I should have made the stops just a tad wider.
    Jan 2011
    Choctaw, OK
    2,755
    Here's some pics of the stop.
    Attached Thumbnails Attached Thumbnails 100_0594 (Copy).JPG   100_0593 (Copy).JPG   100_0592 (Copy).JPG   100_0595 (Copy) (Copy).JPG
    Nov 2011
    Connecticut, USA
    50
    Flyingw, PM sent
    1981 Honda 185s
    1985 Honda 250sx
    kebby28's Avatar
    Nov 2012
    Antrim, NH
    435
    Coincidence? I just finally welded my stops in tonight. Rode it all summer without them saying I would be careful and put them in later. Ended up putting a little ware in the tank but its finally done.
    May 2020
    Tidnish, Nova Scotia
    Hey Kebby I know it's been a while since you posted on this thread, but I was wondering what size tires you went with front on back on your bike? I plan on doing the same mod to my 250 big red. It looks amazing
    May 2020
