Thread: 250r 1 1/8 handle bars?
    Dec 2010
    mass
    20
    I want to put oversized bars on my 250r project. What bend is a good bend for trikes?i want to use the no crossbar kind prob pro taper, im just curiuos what other guys are using and if they like or not.im thinking cr low ? Would you cut them down or would you keep stock lenght? Thanks guys this site rules! Its been a huge help saved a ton of hours reseaching.
    Nov 2013
    I also am curious to see about doing this for a Tri-Z.
    Feb 2013
    Des Moines
    53
    Is their enough cable length for fat bar adaptors?
    STL
    3,560
    i believe my brother atc-eric has a set of pro taper fat bars on his tri-z and he runs the risers and stock cables etc. There should be enough cable length on the atc for risers. I would go with some of the pro taper low bend 1 1/8" bars, they look decent and i think about 70$ shipped on ebay. risers for them are gonna be about 50 or so bucks though.
    Nov 2013
    I trying the 1 1/8" bar mounts.
    http://www.protaper.com/products/tri...-rubber-mounts
    No Adapters and a Pro Taper ATV High Bend bar. So far the mounts are going to work and the High Bend bar is similar to the stock handle bar. This is on my Tri Z 250.
    Blossvale NY
    4,563
    From what I can measure, the bars I like on my R's are some sort of dirt bike low rise, wide, and not much sweep.
    I am not using fat bars with adapters though.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
