Its a big draw on the stater. You can wire directly from the light plug with spade connectors. I would run a xtra ground wire to the frame also. Pull the power off of one circuit. Either the high beam or the lo beam. If you wire one light to each curcuit only one will come on at a time. If you have the cash go for 1 HID light and it will work better than 2 halogins. With 2 halos the lights are dim at low rpm's. They wont get bright until you rev it up.
Shart Guard .......Use it !
Pink Powerwheels Barbie trike
1985 Crash and Burn champ
