Thread: 200x dim headlight
    Oct 2011
    Burgessville ON
    22
    200x dim headlight
    The headlight on my 200x is very dim. When I first got it the light was dim at normal then fine when I revved it up which is normal. Now it takes 10-15 secs to come on when I hit the switch, and it barely lights up. Even when I rev it up it makes no difference. It's easier to ride around with the light off in the dark than to have it on. And the tail light won't come on at all.
    Any help would be appreciated
    6,798
    Sounds like its time for a new lighting coil but check all your grounds good first .
    Oct 2011
    Burgessville ON
    22
    so this lighting coil doesn't effect the spark correct?
    6,798
    Correct its for lights only . Its the larger of the 2 coils located in the left hand flywheel cover .
    Quote Originally Posted by MatthewBuckrell View Post
    ScreaminRed's Avatar
    ScreaminRed is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2013
    NC USA
    391
    On my 350X, it was just dirty connections. Like, Shortline said, check the wiring first.
    '83 Big Red
    '85 350X
    '86 350X
    '06 CBR1000
    '08 Road King
    '11 Electra glide Ultra Classic
    My feedback thread: http://www.3wheelerworld.com/showthr...or-ScreaminRed
    Jan 2011
    Choctaw, OK
    2,755
    Keep in mind the 200 series trikes don't use a conventional regulator. They use the bulbs filaments and wiring to regulate power. Typically if one bulb blows, it will lead to the other one blowing due to an over-voltage condition. Be sure all your connections are clean and replace both bulbs at the same time.
