So I did some searching and couldn't find anything on replacing the fork seals on the 350x. I have this front end installed on my 250es and I noticed one of the forks started to leak the other day. Well after a couple hours of riding it the other fork started leaking.?.?
Well I have never done forks before. I have the manual and I'm a decent mechanic but you folks seem to know all the tricks.
Should I buy this kit for $40
http://www.ebay.com/itm/85-86-HONDA-...c643b9&vxp=mtr
Or can I just do the seals themselves:
http://www.ebay.com/itm/HONDA-ATC-35...7828e5&vxp=mtr
I don't have allot of money but want to do it right. Is there any special tools I need to do this project or any other parts I should do while its apart? And, where is a good place to get a set of black fork boots of similar quality like the blue ones I have on there. Rigid with allot of ribs?
Thanks
ing action is all that's required to pop out the upper Teflon ?? coated bushing with spacer seal and all. Allot of the 200X 33MM tubes get bent pretty easy. Get that lower tube SPOTLESS!!
