Results 1 to 12 of 12
Thread: 350x rear shock springs,were to purchase?
    1,641
    Looking for a new spring for my rear shock,350X.The shock has already been rebuilt.
    fallguy666 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2013
    athens jawga
    201
    Are you booking for a heavier spring or a softer spring?
    1,641
    Something that would work for somebody that weighs 225lbs.
    Sarnia, Ontario, Canada
    3,415
    Stock spring and shock carry my 245lbs frame well..
    You talking about jumping?
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    I'm 220 and my stock X needs to be stiffer, but I need to be thinner....
    The RX rear 450R and 250R shock and linkage are perfect, I do bottom the front on big jumps with 20wt oil and progressive springs.
    So, I moved up to 30 wt but cannot test here unless I build a bigger jump. I'm at 40' or so when I got hurt on a simple trail ride so I have no feedback yet.
    I'm sure most of the shock re-builders can get you a heavier rated spring.
    1,641
    I need to be thinner also.
    I had the rear shock on my bike rebuilt/revalved and checked on a rear spring and he said it was a 600#spring stock and he said they dont make any springs heavyer so he changed the valving and oil weight. It made a big differance in it . And I'm a 300# rider
    1,641
    Not so much stiffer but new.
    nicker71's Avatar
    nicker71 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2003
    Wright City, Missouri
    385
    My shock builder counldnt find a heavier spring for the 350x shock.
    1,641
    I'm sure after it's long life it has lost some of it's spring.Really would like to replace it.
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by jays375 View Post
    call eibach, they make custom springs reasonably priced if they don't stock it.
    Contact: 951-256-8300 x134
    Jan 2013
    minnesota
    5,911
    call to see if they have an orig.
    1- 877-745-3617
    p/n 52401-ha5-003
    http://www.gearhead.com/honda-52401-ha5-003.html
