Results 1 to 7 of 7
Thread: BIG RED d.i.y. SNOW PLOW FINALLY HITS THE SNOW
    Jul 2013
    mo
    327
    http://www.youtube.com/user/effortequalsresults
    83 atc 110
    77 atc 90
    80 atc 110
    85 200x
    85 200x
    87 250es
    79 atc 110
    1978 atc90
    1985 200s
    1985 atc70
    1983 atc 70
    Pacific NW
    4,255
    What a great idea.
    I tried dragging a pallet but the snow was too deep and heavy and no where to go, so it just piled up.
    That plow of yours gives it a place to fall off. and it's SO much fun you don't mind making a few extra passes and no real reson to use reverse 100 times like with a front plow.
    Jul 2013
    mo
    327
    thanks tri again. ya she knocks the snow down pretty good . but it does'nt do it as neatly as the other ones. still gotthe job done. and ya more excuse to ride around and make the nieghbors crazy. hahaha
    83 atc 110
    77 atc 90
    80 atc 110
    85 200x
    85 200x
    87 250es
    79 atc 110
    1978 atc90
    1985 200s
    1985 atc70
    1983 atc 70
    Nov 2013
    Hamilton Ontario canada
    41
    Looks cool, and looks like it works, cool idea man!
    King Trikester is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2013
    Canada, B.C, FSJ
    435
    thats pretty cool, the only issue i see is if the snow get to deep. snow can drift onto your driveway and be 3 feet deep over night. but still a cool idea, it looks like it could be a bit heavier and mayber wider? Im not trying to knock on it at all its 1000000x than the shovel I use (for now) but it looks like it could improve
    bigdaddyvw185's Avatar
    bigdaddyvw185 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2013
    Seymour CT
    314
    sweet idea!, id suggest adding some weight. either by installing a heavier steel plate onto the bottom of the plow, or over the rear wheels like off the back or something. weight over the rear wheels will help keep it from bouncing around when the plow is pulling a full load of snow. good deal tho man!
    Jul 2013
    mo
    327
    Quote Originally Posted by bigdaddyvw185 View Post
    ya im think of some kinda rack back there . a gas cylinder cut in half and a tube of sand would be great. i still need to tweak it. but in all hindsight i should have plowed the night before but i want to vid it up during the day and we got more than expected so it was a hard first day out with it.
    83 atc 110
    77 atc 90
    80 atc 110
    85 200x
    85 200x
    87 250es
    79 atc 110
    1978 atc90
    1985 200s
    1985 atc70
    1983 atc 70
