Results 1 to 7 of 7
Thread: 200x. Engine paint "oem"
    PAPA250r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    greentown PA
    389
    Can any one recommend a paint that closest matches an original 85 200x ? Found an all original low hour trike but the damn engine suffered peeling lol... Trying to make it look as original as possible thanks
    84 200s almost done
    84 atc 70 project
    Sep 2011
    New Castle, PA
    1,134
    pj1 fast black
    If you do the whole engine remeber to shave paint off of the head fins. looks soooo cool and that is an OEM detail
    Gone:
    nik0708 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aberdeenshire, Scotland. U.K
    417
    Hammerite satin black smooth, it's the closest I have seen to OEM finish.
    Willamstown PA
    5,824
    I use VHT gloss black. It chips off mad easy and I even took it to bare metal, primered it, heated 400 degrees, painted and heated 400 degrees again. nicest will be powercoat if your fussy.
    the VHT does not ripple off when you get gas on it however. I got it at autozone.
    Sep 2011
    New Castle, PA
    1,134
    You bring up a good point oldskool. I was going to suggest powder, but I got beat up by some "professional" painters on my build because it's too thick and the engine can overheat.
    I've had no problems with it, so I guess powder gets a Click image for larger version.
    Gone:
    Feb 2009
    greentown PA
    389
    I have used pj1 and very pleased with it .... i am assuming the gloss version and not the Satin / flat one ?
    Satin looks nice but dosent look OEM to me lol
    Rg97 - i always shave the fins lol
    84 200s almost done
    84 atc 70 project
    Sep 2011
    New Castle, PA
    1,134
    Honestly, I think that the flat one looks better, but it's your bike, not mine
    Gone:
