Just like the title says, it starts and runs perfect. You can stab the throttle no problem but the quad does not hardly want to move under its own power. I was starting to think it was the throttle cable but pulled everything apart and the slide is opening fully and closing off. I am starting to think the clutch is going bad or something? can anyone provide any input on this problem? is there a way to check or adjust the clutch? Maybe it got wet or dirty? I am about to pull the cover and look at it but wanted to eliminate any other issues first. The carb is spotless and good fuel flow. The intake is clean but i am going to remove the restrictor this afternoon. Also going to pull the exhaust just to check if its plugged up somehow. Brand new spark plug and airfilter, so i am running out of options. Somebody please chime in and give me some ideas.
Also looking for a service manual if possible for this beast.
I have tirelessly searched the internet for some answers and found lots of threads where people asked similar questions but absolutely no responses. This place is full of geniuses so I figured someone here can actually help me out. You haven't let me down yet. Thanks in advance for your help.
