Thread: my X bearings wont come out!!!!!!!
    i cant get my front bearings out of my 200x anybody have any pointers.
    kwit is offline First Time Rider Arm chair racerNew to the board
    Dec 2002
    134
    yup
    littel wd 40 and a bigger ....or u could take off the swingarm and bring it to a machine shop and have them pressed out
    current bikes: 1985 200x,Tricked sport goped,2003 magnum 330 polaris(my dad won it)
    old bikes:tricked racing 97 blaster,1983 kx 80,1983 200e bigred
    JMiller's Avatar
    JMiller is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    put some heat on it!!!
    Current Rides:
    '87 Tecate 3
    '84 Tecate 3
    yater is offline Just Too Addicted Arm chair racerJust too addicted
    Jun 2003
    Tyler, Texas
    672
    what bearings are you messing with? If it's the front or rear axle, I use an iron rod about an inch in diameter to stick through from the other side and the bearing out. Lots of wd40 won't hurt anything either.
    roofinggun is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2003
    202
    bearings
    If you just lay it on the floor and take a 12" 3/8 drive extension and hit it with a BFH using the round side, they will come out. If you have never used heat to remove a bearing I would not recommend it, you can really do some damage if you get it too hot.
    hondaatcvabeach is offline At The Back Of The Pack Arm chair racerFirst time rider
    virginia beach
    241
    I got mine out by getting a long but thin pipe, put the end of the pipe (or something long you can hit) on one side of the bearing, give it a good wack. Then put the pipe on the bearing again but directly on the other side and hit it again. Repeat this as needed, but be shure to only hit it in the same two spots, this will not give it a chance to reset itself. If that dosen't work send me a plane ticket and i'll get it out for you. :bounce
    1985 Honda 200x (200s motor)
    1984 Honda Big Red (200ES)
    1985 Honda 250SX
    1984 Kawasaki KLT 250
    1984 Honda 70 (Daughters)
    1981 Harley Davidson Roadster
    PROUD TO BE FROM THE LAND OF COTTON
    Check out my units website 3dvirginia.com
    *******GO DIXIE********
