Thread: 1985 Honda 250 SX one way clutch direction
    May 2005
    Illinois
    65
    Can anyone tell me what direction the outer on the centrifugal clutch should spin when replacing the one way clutch? the new one I bought isn't marked or stamped side out. so outer on centrifugal will spin clockwise or counter depending on which way I insert the new one way. thanks.
    IDK, but turning over the motor with the kicker would tell me what direction it drives and then freewheels.....
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by bearclawchris View Post
    Hi;
    The same direction as I mentioned on your thread in the new member discussion area a few hours ago, counter clockwise.
    Happy Holidays.
    Sarnia, Ontario, Canada
    3,415
    This is a fool proof way of knowing..if you install it and it free runs in one direction and stops the other, you have it right. If it is locked up in both directions you have it in backwards..take it our and reverse it.
    This is what I found when I replaced one on mine. Didn't know at the time what direction, but when I installed it this is what I found.
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Larry T Moore is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2013
    Indiana
    358
    the bearing says on it which way goes out...at least mine did..
