I think I'm dealing with a weak spark on the Stud Duck. Here's the deal, I cleaned the carb & have been thru it 3 times, everything this is good, gas is pumping thru & floats are the best they have ever been. I found a piece of trash in the reeds, so I took them out, cleaned them & rubbed them slightly with the brass brush. I boiled the intake & tube from the air filter to the carb, they are as tight as ever. I've tried using a brand new spark plug, the plug I've been running for about 6 months, & a hotter plug, I think its an 8, I can't get the little guy to start with any one. I got some starting fluid, still nothing. I pull the plugs out & the spark just doesn't look as strong as it has been before. I've tried push starting, it'll turn over good, but it won't pick up & start going. I've got the manual & plan on going thru each electrical check tomorrow or Monday, but from experience is there a simple fix, or something that goes wrong more times than not? I tried to take the ignition coil off the frame to clean the ground, but the screws are rust welded to the frame now, so they're soaking in P'Blaster. I've triple checked all, let the plug stay out for a few hours for the cylinder to dry out, just in case of flooding, the plugs come out wet, but not soaked like a flooded cylinder. Everything was perfect the last ride, & just a quick check list-the gas is fresh 93 octane, kill switch is on, & I'm standing in the superstitious stud duck starting position every time! Drop some knowledge on me guys!
