so I got my new steering stem bearings and am going to install them but.... they don't come with instructions and they aren't the loose ball bearings that are stock in my trike. these are made by Boss bearings and are just a tapered bearing with a sort of "cup" it sits in, then a seal type piece. I'm not sure how they go in. there's one for the top and bottom of the steering stem, I know which is which... but after that I'm lost. I took apart the extra steering stem I had on another frame to sort of try to figure it all out but didn't get too far. I removed the triple clamp, slid the stem out, took the balls out, popped out the cups inside the neck of the frame... then? the bigger one goes into the bottom... taper side up into the neck or facing downward? then the top one? does it go into the neck or over the stem? it seems too loose to go into the neck... but the iD of the bearing is good for slipping over the stem! do I leave the stock bearing cup/s in the neck?
