Results 1 to 11 of 11
Thread: DG Pipe Mod
    Feb 2003
    New York
    623
    DG Pipe Mod
    I am sure someone else has done this but maybe not. If so I wanted to tell you that I did a mod on a DG pipe that works pretty good. First off its too damn loud. So what I did was find a way to quiet the pipe down and gain more power.
    I drilled 3 holes into the back of the steel baffle and installed one super trapp disc. The disc I used is an end cap. I drilled 10 small holes in the center of the end cap. Now the pipe is a little bit louder than a stock honda can but has the power of a supertrapp.
    If anyone is handy there is a way to get the supertrapp discs mounted on there. Total cost 112 dollars for the DG slip on and a few dollars for one supertrapp end cap.
    Its a reverse megaphone pipe so it does the same thing.
    Now I can ride through the trails without being too loud.
    It will still have a nice note to it but at least 50% more quiet.
    Tons of back pressure.... excellent throttle response.
    Running Mikuni closed air box with NOS 350X air filter.
    Probably be even more responsive with a UNI.
    ♠ 58 ♠
    Ride 3
    Scootertrash's Avatar
    In the sticks
    4,638
    What? No Pics??
    JustEnough's Avatar
    JustEnough is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2009
    Elk Grove, CA
    334
    I took a 8" length of electrical conduit and pinched one end shut then drilled about 40 1/8" holes in it then brazed it into a disc with a hole that just fit in the tube of the DG pipe. It was as quiet as stock and did not seem to have excessive back pressure. The brazing eventually broke loose likely because the pipe and disc were not thick enough for me to braze it strong enough. I am going to try the same design with thicker pipe and thicker disc and weld it. I then plan to sleeve the pipe with stainless mesh to make it a spark arrestor that can be cleaned.
    If you know of a product that drops right in that pipe, that you can buy, I would like to hear about it. When I called DG to see if I could buy something from them, the guy literally laughed at me.
Name:	DG Muffler Core.JPG
    Feb 2013
    Senoia, Ga
    635
    What? No Pics??
    X2! Let's see it!
    Feb 2003
    New York
    623
    I took some pics, also a link to a video so you can hear it
    You wont get any noise complaints trail riding with it set up like this and you will get more power. You can always remove the cap if you want to get loud.
    I had both supertrapp and now this DG set up and they are about the same
    performance if you keep the cap on. For 120 bucks its worth it.
    https://www.dropbox.com/sh/v1hvqhqwb9j4yja/5FjV-JC1qu
    ♠ 58 ♠
    Ride 3
    Feb 2003
    New York
    623
    2 more pics
    2 more pics. 45 degrees today. Heat wave.
    ♠ 58 ♠
    Ride 3
    Mar 2007
    Texas
    5,045
    looks good.
    ________________
    https://www.mikesatvfix.com
    Andy, whats up!
    The less number of discs, the less noise and affects your power. The DG stock A/M pipe is terribly loud!
    Is that the same trike I did all the work on in 48 hours??
    I run 13 discs and a big main jet; That's where the power is for me.
    Take the A/B lid off and add 15 discs and have a top end screamer!!
    Glad your still in the game.
    Happy New Year Andy.................
    Feb 2003
    New York
    623
    I wish this was the 48 hour pit bike you rebuilt but its not. However I am very happy with it and hanging on to this one. This pipe was 112 bucks and is a reverse megaphone RCM steel slip on. I am using the stock head pipe.
    Louder than cobra. Its just right the way its set up now. The mikuni carb really does help wake it up too. 15 discs Steve ?
    Where do you have enough room to get through the 6 gears ?
    The 350X has more gears than my road star warrior 1700. We gotta get you up and running on a street bike real soon. Promise me no wheelies..... happy new year steve
    "the fastest wrench hands on the east coast".
    ♠ 58 ♠
    Ride 3
    Same to you Andy.
    No street bikes for me; I am smart enough to know one will kill me, then you can all call me DEADCRASHER!!
    We don't want that just yet
    Lots to build and do, it is all coming together this year. Next build is a super trick custom ATC70 suspended!!
    Then the FCR carbs on both the 200X and the 350RX; Porting as well.
    Jul 2011
    Eau Claire, WI
    1,188
    Quote Originally Posted by sweetip2000 View Post
    I have an aluminum DG pipe I recently cleaned up and welded new mounting tabs onto. It's been bead blasted inside and out. Currently it's reassembled without any packing inside. Would I benefit from this setup after I rebuild my 82 ATC200 with Wiseco 10.25:1 piston and 200X cam? I assume it would wake up a stock ATC200 motor as well?
    I don't know anything about Supertrapp pipes. I've looked on eBay a couple times but don't have a clue what I'm looking for? The DG 3.5" across the can. I can't seem to locate any 3.5" Supertrapp stuff? Can anyone point me in the right direction, please? Thank you.
    86 Honda ATC 200X Frankentrike (Project)
    80 Honda CB650C Conversion (Project)
    3WW Feeback Thread For DasUberKraut
    Retired Machines - 02 Honda TRX 300EX, 85 Honda ATC 250SX, 84 Honda ATC 200X Astro Kit, 85 Honda ATC 70, 85 Honda ATC 200 Auto-X, 83 Honda ATC 200E Big Red, 84 Honda ATC 125M (X2), 82 Honda ATC200, 81 Honda ATC 185S, 81 Honda XR250R
