I have an '83 200x. I was wondering if someone has any idea how much it will cost to fix. It slips in 3rd gear, needs front brake pads, the rear sprocket is loose, and the engine probably needs rebuilt.
slips in 3rd is the clutch 60 to 100$
front pads $20-30
sprocket bolts $10
piston kit and bore cylinder 150-200$
less than 250$ for top of line stuff = worth fixn
Wow, that's less than I was expecting.
That's what I was thinking. Hopefully I can get it fixed up soon. I'm thinking about buying black plastic for it too.
Have fun trying to find black. I dont think anyone makes it. You can check maier, but I doubt it. MAYBE someone on here has a set?
Your sprocket problem is most likely more than bolts, but tell us this.... does the sprocket move side to side (need new bolts), or does it rotate without the axle turning? My sprocket rotates about 1/4" without moving the axle and it is the splines on the inside of the axle adapter (that star-shaped piece that connects the sprocket to the axle with 5 bolts) that are worn down.
The engine "probably" needs rebuilt. How do you know? Is it smoking bad? leaking oil around the head? something other than 3rd gear?
I dont know how much it is to replace 3rd gear, I've never had that happen on my X. It may involve a new or used-but-usable countershaft and/or gearshift forks from fleabay. I just did a quick search on there and there is a complete running transmission from an 85 X that is $90 with shipping.
But anyways
Gaskets will run you about $80 if you go OEM honda (I strongly recommend that over aftermarkets)
My local shop does single cylinder boring/honing for either $60 or 80, I forget
Piston will be about $100-150 depending on overbore and brand (recommend complete wiseco kit through eBay)
Valves OEM will be $45 apiece, or you could go the vesrah budget route (do not recommend!)
I do my own valve lapping so I dont know how much a machine shop would charge you.
If you go to a high comp piston, i recommend powroll's high strength cam chain. It's $30 and it's worth the added insurance that you dont blow a chain and bend your valves and ruin your piston. Look at their website www.powroll.com for phone #
Brake pads are cheap, about 20-30 bucks.
That sprocket problem can be anywhere from $5-50 depending on the severity of the problem.
That right there is $465-590 WITHOUT a valve job.
It's your call.
Why do I feel like barnett after writing that?![]()
Gone:
Maier makes black plastics but they are NOT cheap. The rear alone is $216 by itself, front is $90, shrouds are $37 for the pair but I find that NOS ones can be cheaper. Shipping charges are probably going to run that up pretty good.
There is nothing wrong with Vesrah products.
In fact. Many manufacturers recommend Vesrah when OEM is not available.
Vesrah is the closest you find to OEM quality. Hands down. It's a proven fact.
86 Honda ATC 200X Frankentrike (Project)
80 Honda CB650C Conversion (Project)
3WW Feeback Thread For DasUberKraut
Retired Machines - 02 Honda TRX 300EX, 85 Honda ATC 250SX, 84 Honda ATC 200X Astro Kit, 85 Honda ATC 70, 85 Honda ATC 200 Auto-X, 83 Honda ATC 200E Big Red, 84 Honda ATC 125M (X2), 82 Honda ATC200, 81 Honda ATC 185S, 81 Honda XR250R
I know a guy that can probably fix it for me. He likes to work on them in his free time. If I tore it apart I doubt I could get it to run again!
When it's for myself, of course. Whats wrong with that
I don't usually work on other people's stuff
I've never used them before, and still don't plan on them unless it's a last resort and OEM's don't exist.
When I originally said Vesrah i was including all aftermarket brands that sell things cheaper than OEM. Vesrah is the first name that came to mind. You just have to be wary of the cheap made in china stuff. Vesrah is made in japan I'm pretty sure
Gone:
I fixed all my 200x motor issues with a full rebuild with all new bearings every one. total $900 with corrected kicker and back cutting of gears...oh and i added ported and polished head and intake to that number.
Bust it runs smooth like a new machine![]()
Just bought black plastic from zmperformance on ebay. $181 + $15 shipping, rear. $75 + $10 shipping front. Cant find shrouds to save my life.
As far as project cost, as has been highlighted here, it really depends on the labor cost.
3rd gear, be more specific, does the clutch slip? (indicated by the engine revving higher than it should while engaged in any gear) or do you think the gear is damaged (noisy, may jump in and it of gear, hard to shift etc.) because that will also be a factor in the cost to rebuild it.
For $700-$800 you can just go buy another running X, the whole thing.
