Page 2 of 2 FirstFirst 1 2
Results 16 to 27 of 27
Thread: '83 200x, cost to fix?
    Apr 2010
    Indian Falls, NY
    1,289
    This is a rough estimate....To rebuild the motor correctly you are looking between 350 (if you are doing it yourself) to 800, maybe more (if you are having someone else do it).
    My dad had our old X motor rebuilt for way cheaper than 350....and it was BUILT.
    But then again this is probably 15 years ago.
    N/A
    5,818
    well your dads just cool aint he lol. if you take this motor to a shop no one will know wtf to do or it's issues. just rebuild it your self. thats what i did. rebuild to me means all new bearings and seals and bore job...not halfazzed rebuild using old crank bearings and rod bearings like a dealer will do for ya.
    You'll be a grand into it easy!
    Allot of that stuff doesn't just "slide apart" after all these years, ya know?......
    Sep 2013
    Coggon, IA
    113
    I know it's not the clutch slipping. It's the 3rd gear problem that a lot of 200x's have. Like I said I plan on having someone work on it for me. I didn't grow up with somebody showing me how to do things. I would probably just mess it up.
    How many teeth are those and any other specs?
    A guy sold me a box with a few NOS ATC gears, no bags and a crapshoot but no good to me.....
    Sep 2011
    New Castle, PA
    1,134
    20T on the mainshaft, 29T on the countershaft
    Mainshaft gear has four "teeth" on both sides of the gear to hook into 5th and 4th gear.
    Countershaft gear is smooth on one side and has four "teeth" on the other to hook into 4th
    Gone:
    Apr 2013
    VT
    147
    I just did a rebuild on an X this summer. I tore it down and put it back together myself. However, You might need someone to look at it. It might need more than just rings. I had to bore over and that means that someone else does that (labor cost). New piston, rings and whatever else. Also new gaskets and "O" rings etc. In the end it cost me in the $500 - $600 dollar range. Just be prepared, you never know what it might look like inside.
    1986 ATC250R
    1986 ATC200X
    1985 ATC200X
    He also mentioned brakes, so I would rebuild that caliper and the sprocket is probably the rubbers in there that I think are gone.....
    Wonder why 83-85 needed those but not 86/87? Maybe because not everyone adjusts them parallel??
    Sep 2013
    Coggon, IA
    113
    I've decided I'm just going to put top end gaskets in it and see if that stops the oil leak. Then I will need front brake pads. Anyone know where to get some?
    The Open Road
    4,736
    Quote Originally Posted by rg97 View Post
    Have fun trying to find black. I dont think anyone makes it. You can check maier, but I doubt it.
    Maier makes black fender sets....I know this because I have a set of black on my sons X....bought them off ebay new from zmperformance I believe
    Sep 2011
    New Castle, PA
    1,134
    They don't make scoops in black
    Gone:
    N/A
    5,818
    ebay for everything.
