Results 1 to 15 of 25
Thread: What the f#ck!!!!!
    Jan 2011
    Choctaw, OK
    2,755
    What the f#ck!!!!!
    So I'm refreshing a motor to put in my mockup. The motor I'm refreshing needs an outer clutch as the one in there is cracked so I pull the cover on the motor in my mockup to pull the clutch and find this. WHO DOES THIS CRAP!!!! Welded the centrifugal clutch to the end of the crank!!!!! I"M SO PISSED. Now I have the split the tranny so I can get the clutch off. I'll cannabilize a few parts from this turd motor and toss the rest in to the trash. F@cking IDIOTS!!!!!!!
    82 250r's Avatar
    82 250r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2007
    Utah
    278
    Hmmm...
    Judging from the quality of the weld, he apparently ran out of plate to practice on.
    Mexico
    9,018
    That right there is a shoe in for those "I fixed it!" emails that go around once in a while.
    kebby28's Avatar
    Nov 2012
    Antrim, NH
    435
    Hehehe, thats one of a kind there.
    Just curious, isn't this just to test carbs on?
    Oct 2008
    NB, Canada
    852
    Welding shifters and stuff on is one thing... this is far beyond that...
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    Always Hoping For a Maritime Trikefest- http://www.3wheelerworld.com/showthr...s-where-you-at
    "Wear Limits Are Just A Suggestion"
    Dec 2009
    Oklahoma
    780
    That is pitiful
    Sep 2011
    New Castle, PA
    1,134
    5 year old to dad: "Daddy, I want to learn how to weld!"
    Dad: "Stick welding is easy, lets start with that"
    Kid: "What can I practice on?"
    Dad: "Howabout this here ATC motor? These things are banned, nobody wants them anymore and that danged clutch was always a problem"
    Kid: "COOL LETS DO IT"
    * One hour later *
    Dad: "I've seen better, but you'll get better!"
    Kid: "YAYAYYYYYY"
    Gone:
    Jan 2011
    Choctaw, OK
    2,755
    Yes it is Kebby but the motor needs to run normally. All I needed was the friggin clutch. 2 hours later I finally got it.
    Oct 2012
    WI
    499
    Quality fix right there!
    1983 ATC 200x
    1982 ATC 250R X2
    1983 ATC 250R : Future build
    1985 ATC 250R : Main rider
    1985 ATC 363R Duner
    1985 ATC 250R X2 : Future build
    1986 ATC 250ES
    N.E. Ohio
    2,002
    Did you run all the way to your key board swearing like a sailor after his first bad tattoo and case of crabs? I fully understand your frustration with the issues at hand. Remember what a good deal you got when you bought it? Ring a bell we have a winner. I never want to see a post like this from you in this kind of language. Clean up your act and remember this is a sight for all eyes to see, so make it read for all ages to enjoy. Do you think it's the first time this kinda work has been passed on? It just so landed in your garage...which from your temper I'm guessing the walls look like Swiss cheese from all the wrench throwing going on. Please do us all a favor...change your tune, or go to Bi-polar, Emotional wrenches.com to locate some more like minded folks as yourself.
    If it took you 2hrs to split the engine down...your smart enough to write like it did. TrailPro!
    Jan 2011
    Choctaw, OK
    2,755
    Point taken Tri-Z and yes I did. Normally I don't get excited like that but this one really pissed me off.
    Jan 2011
    Choctaw, OK
    2,755
    Thanks for editing my post. You beat me to it. Pressing on now!!!
    Mar 2011
    Louisiana
    208
    You get what you pay for. What you got?
    Jun 2009
    Leander TX
    2,217
    Wow - I would never have guessed someone would do that. That would set me off on a fit, too. Things get broken when I have a good fit...
    honda4h's Avatar
    honda4h is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    ottawa ontario
    361
    that's a common redneck bolt. used buy many rednecks.
