Results 1 to 15 of 15
Thread: Advise wanted on how to install a wood stove in an unfinished garage
    timex69 is offline Just Too Addicted Arm chair racerJust too addicted
    Sep 2003
    Saskatchewan
    485
    Hey Guys
    I just bought my first fixer upper house and as luck would have it, it came with a brand new 24 x 16 garage. The downside is there is no heat or electricity in it yet so after checking with my city hall, local building inspector, fire inspector and insurance company I have been given the OK to install a wood stove in a detatched garage.
    I went out and purchased an Englander Stove and had a frame made to raise the fire box up off the floor 18". Now for the part I am unsure of. Since the garage is unfinished there is no "ceiling" for the stove pipe to travel through just the roof and every chimney kit I look at is designed to go through a floor then a roof. Can I just run stove pipe between the rafters that are 16" centers with a heat barrier on either side and connect it to a chimney below the roof or do I have to get a long enough chimney to come down between the rafters and reach up through the roof.
    Any help would be appreciated.
    Sarnia, Ontario, Canada
    3,415
    90' elbow out the wall and up the outside of the building..provided the top of the chimney pipe is above peak of the roof. Exact distance above peak, I'm not completely sure..check with build code.
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Michigan
    1,144
    I would stay away from elbows if possible. I would frame in around the rafters where the pipe is going and install a good insulated pipe from the ceiling up through the roof. Here in MI where I live you can get as close as 2 inches to the insulated pipe. I have had mine in my house for 13 years and have never had a problem. Use a double wall insulated pipe from the ceiling up through the roof.
    85 Big Red
    83 Big Red
    84 125m
    85 TRX 125
    73 ATC 70
    Sep 2003
    Saskatchewan
    485
    Thanks for the quick replies. I'd rather not go with the out and up install. I have seen alot of people do it but to do it to code in my application will cost far more then doing a straight up install.
    Hublake: I am going to run this idea by a building inspector tomorrow morning. If not allowed I will need to get a flu box and 4 foot insulated chimney and install it at the ceiling and go up and out from there.
    Connecticut
    1,605
    Good luck, I hope your inspector is willing to listen to your wish of going straight to the roof using double wall pipe
    Sep 2003
    Saskatchewan
    485
    Straight to the chimney just below the roof, not through it with just double stove pipe just to be clear. But yeah I hope so too. I have no intentions of insulating the ceiling but code is code so ill let ya's know when I know right and wrong.
    May 2011
    eden,ny
    3,481
    Quote Originally Posted by timex69 View Post
    couldn't be any more clear.
    Michigan
    1,144
    Look up Selkirk Metalbestos on Google. That is the double walled insulated pipe I used.
    85 Big Red
    83 Big Red
    84 125m
    85 TRX 125
    73 ATC 70
    Sep 2003
    Saskatchewan
    485
    I'm going tomorrow to pick up one of the Selkirk chimney assembly from the hardware store. Seems like a quality setup and exactly what my insurance company is after with all the stove pipe being double wall. I've been to Canadian Tire and looked at their chimney setup and they sell every piece seperately and unless you know exactly what your looking for it's quite a task.
    If running a gas line and installing a natural gas overhead furnace wasnt so expensive that's the way i'd go. On another note what are you guys burning for wood. Up here in north eastern Saskatchewan jack-pine, tamarack, poplar and birch seem to be the norm however birch is about 350 for a blocked and split cord delivery is extra and poplar is damn near free but its hardly worth the gas money to go get it.
    Michigan
    1,144
    Here in MI most people use oak. Now there is a lot of ash being used as the trees are dying after being attacked by the Ash Borer Beatle. Wood here is around $55-$60 a face cord. Same here with poplar.
    85 Big Red
    83 Big Red
    84 125m
    85 TRX 125
    73 ATC 70
    Austin, Massachusetts
    1,591
    i'm about half way through the process of putting in a stove in my barn right now. i started about four days ago and it had been a process.. durorock, tile, etc, etc,..... the pipe was expensive. i'm going straight up through the roof. its been a learning experience.
    Wubba Lubba Dub Dub!!!!!
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    85 Yama 225DX - The Rental!
    150cc Piranha powered 70
    110cc Lifan 70
    82 70
    83 ALT 50 Trail Buddy
    88 Yamaha BW 80
    84 z50
    Sep 2003
    Saskatchewan
    485
    redsox
    How far along are you with your install? Im about to cut the hole in the roof tomorrow. I have the stove in place elevated to give me the required 18+ inches of firebox elevation. The double wall stove pipe is is in place and screwed together at the joints. The flu box has been framed in and nailed to the rafters ready for the chimney to be installed tomorrow. Im just waiting for the cold weather to break to continue work. -35 doesnt allow for very much progress. I'll post some pics tomorrow. I agree with you its definately a learning experience, between calls to the building inspector, fire inspector and chatting with my local co op building supply store about all the materials I would need plus a few evenings of reading up on the internet. Almost $2000 dollars later I am nearly finished. I cant wait after working in the garage with a kerosene blaster heater for the last 9 years I cant wait for clean, vented heat.
    Pacific NW
    4,255
    Quote Originally Posted by hublake View Post
    Isn't that stuff triple wall? 2 inch to wood?
    Expensive but I've also seen it for sale used.
    New thought is to keep the exhaust gasses Hot so they don't crystalize
    on the way out.
    I just had a freighttrain chimney fire so I changed most of my pipe to metalbestos triple.
    Amazing how much heat, smoke can lose on it's way up and deposit crystals.
    Glad you're conferring with the inspectors.
    Preserves your homeowners insurance too.
    MNhondaguy's Avatar
    MNhondaguy is offline At The Back Of The Pack Arm chair racerFirst time rider
    Sep 2013
    fergus falls, mn
    203
    If you get the one made for ceiling then roof, it won't be an issue later if you decide to put a ceiling in.
    83 ATC 200E(X) Big Red
    My YouTube- http://m.youtube.com/user/mazdarattiman
    My bros (hoopster3030) YouTube- http://m.youtube.com/user/hoopster3030
    B vents not cheap; Doing it properly to save everything you enjoy from a tragic loss is far worth it.
    So, you don't have a chimney correct??
    You can run regular (I suggest 26 gauge) 5' lengths of stove pipe and then B-vent thru any now/future ceilings and the roof. And as said before, above the peak of your roof or whatever your code requires. In the US, sometimes city codes override state requirements.
    B-vent the whole way is not necessary and will add to the cost and you lose the heat transfer from the pipe itself.
    Yes, the less 90's the better. 2 - 45's to offset it into a center of a truss or roof rafter, then B vent thru and use a (pitch sealing thingamabopper, I'm forgetting this chit ) thru the roof with a drip ring and a hat should be cost effective and safe.
    I have a VERY WELL insulated 16x20 so I have a 230V electric industrial heater with a fan (thanks Victoria Secrets back storage hall) and it barely runs once I'm at 65-70 degrees.
    The thought of quitting for the night and having a fire with a wood stove settling down has always terrified me.....
