Thread: Tri Z jetting
    atcrider1's Avatar
    atcrider1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2009
    Montrose MI
    400
    Tri Z jetting
    What's the stock jetting for an 86 Z? I got it with the stock pipe an a uni filter in the factory box, it had a 310 main. I put on a dg pipe from xowner and it ran good but would eventually starv for fuel. I upped the main to a 380 and it ran better but after riding for 5 mins it will bog out and die. If I choke it it will barley idle and die when I touch the gas, upped to a 400 main and does the same thing. How should I jet and tune it for a full dg exhaust and open air box with a uni? Temp has been around 20 degrees
    " I gotz the 8-track player mounted to my Oly, it's pretty sweet for trail side dance parties....."
    -Uller God
    atcrider1's Avatar
    Mar 2009
    Montrose MI
    400
    It also has been starting very hard. Usually wont fire till I give it a shot of starting fluid
    -Uller God
    North Dakota
    1,643
    Mine was doing the exact same thing! Wish I still had it if you can get this figured out! I ended up selling it for an Fl250. I still can't believe I did that! >.<
    Mexico
    9,018
    To start a Tri-Z that has been sitting for a while you take the fuel vent hose out of the steering head nut and blow into it. This puts pressure into the tank and fills the float bowl that is too low to feed the engine on the first few kicks due to evaporation (I learned that AWESOME trick on here!!!!) Your trike will start in one or two kicks.
    As far as your jetting goes it seems more like you need a fuel pump rebuild than a jet change. Deal with that first, check the lines, fittings and filters and THEN worry about your jet sizes.
    Nov 2013
    Stop using starting fluid on a 2 stroke. Your going to seize it.
    Are you running a Air Box Lid?
