Thread: '85 110 engine into an '81 ?
    Jan 2013
    United Kingdom
    28
    Hopefully a quick question with a quick answer;
    Will an 84-85 atc110 engine go straight into the earlier ('81) trikes?
    Thanks in advance.
    MN
    3,263
    Frame wise and such yes, they will bolt right up no problem. You will have some small differences in electrical, but otherwise its a bolt on swap.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Feb 2013
    chicago il
    505
    yes it will fit right in. I have 84 cdi motor in a 79 110 frame. I would swap over the entire harness if you have it. just to be safe. However if its an 81 it should have a cdi motor in it already and connections should be the same.
    Trikes: All Honda: 84 250r, 85 86 and 87 250sx, 84 and 85 125m, 79 82 84 and 85 110's, 73 us 90 and 77 atc90, 75 atc70
    Cycles: Honda: 71 cb100, 78 cb750 coming soon cb750 trike. Yamaha: 67 yds 3 (250cc, 2cyl, 2 stroke), 82 750 SECA
    Other toys: Chenoweth VW sandrail dune buggy, old race go kart, racing mower, 76 Arctic Cat Pantera 440 snowmobile
    KEEP IT ON ALL 3 OR AT LEAST 2 AT A TIME
    Jan 2013
    United Kingdom
    28
    Excellent, thanks chaps
