Results 1 to 12 of 12
Thread: Death Rev
    Nov 2010
    Louisiana
    109
    Death Rev
    So I was thinking my death rev was because I didn't put the needle in the slot in the carb correctly upon reinstallation. I pulled the carb, everything seemed fine. I took to shrouds and seat off just to look and WOW. The black and red wire had melted and had a nice black area on the frame. the plug wire was just spinning to where the internals were making sporadic contact with the ignition. Jesus, I neglect her for a few months and she gets Pis#$%. Almost like a real woman (no offense to the ladies that read this) Oh well. Will get new plug wire, and electricals.
    Thx
    Jarrod
    STL
    3,560
    Don't think I have heard if a reason like this for a bike revving out of control but good job figuring it out! Let us know if that fixes it once replaced
    Baltimore, MD
    6,088
    First I heard of that reason. Usually fuel related.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Smile
    Did the over-revving cause that??
    I'd make certain that the carb slide or throttle valve is free and that there are no air leaks. Otherwise, it's that electrical deal.....
    No worries, plenty of woman are on the "take until I can support myself" wagon
    NOT the lovely ladies from 3WW
    They all rock!!
    Abrams, Wisconsin
    739
    Contact, spark, or whatever, without fuel it cant rev. Check your carb and intake over good.
    86 250sx - old reliable
    another 82 110
    -gone but not forgotten-
    82? 110 - why did i sell it??
    84 225dx - meh, it was a pile
    kebby28's Avatar
    Nov 2012
    Antrim, NH
    435
    When I saw Death Rev, I immediately thought air leak...
    kebby28's Avatar
    Nov 2012
    Antrim, NH
    435
    Kinda like when a chainsaws running out of gas, not good.
    ktmbk's Avatar
    ktmbk is offline At The Back Of The Pack Arm chair racerFirst time rider
    Long Island
    154
    I lost an engine to "Deth Rev", it turned out to be a air leak. I would defiantly check for one
    STL
    3,560
    I had bad death rev a few times on my 500r because of debris clogging the pilot jet.
    May 2011
    eden,ny
    3,481
    Quote Originally Posted by ktmbk View Post
    and that's why its called a death rev. The only way to stop it is putting the bike in gear and kill it with the rear brake or cut the air of to the carb. some times the choke will slow it down enough for the kill switch to work.
    Jackson MI
    1,688
    Usually If the engine is revving and can't be stopped it is because of a lean condition, sucking air, or starving for gas. So if it ever happens again, slam the throttle wide open, and it will shut right down.. Sounds wrong, but it works!! It won't work if your throttle is stuck, but if the throttle is closed, and it's revving out of control, opening the throttle bombards the engine with air, and it will shut right off.
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
    toki is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2011
    wisconsin
    158
    i would have to agree with everyone here.
    and my 2 cents.
    death rev = lean, sucking air from somewhere. If it was a spark issue it would not lean out and death rev because it would now have more unburnt fuel... and not "death rev". Build a cheap leak down tester! they only cost like 10 bucks to build and will save you a TON of money and guesswork. if you need info on what to get let me know.
    air leaks happen. crank seals, base gasket, carb boot, head gasket, reed cage.. blah blah. heat can also make a sealed engine leak. i've thrown a pair of welding gloves on and ripped my pipe and carb off quick to find a leak once. my old (83 250r) is verrrrrry picky. I had a small leak at the exhaust. It has the stupid ring its supposed to seat against and even brand new from the factory that couldn't have sealed very well. once hot the engine would start to pick up and rev slowly and not return to idle. i chased this problem for 3 months! all it took was a new ring and a coating of rtv silicone. done.
