Originally Posted by
czac
sounds Chinese to me... secondary, primary... lol I just hook up a new one and if it works, fine, if not, try another one. Hard to imagine three coils going bad...
on another note, cant you cut the short wires and make them longer? I had to do that on my key switch, the one I bought was obviously not from a YTM 225 like the Ebay ad said it was because it was about 4 inches shorter than the one I had... so I cut the wires and added the longer wires from my old key switch and attached them with bullet connectors... problem solved. How cold does it get where you are? is it like below 0 for days at a time? because we went through a little cold snap where we had a couple below 0 days in a row with wind chills of about -10 or so and my 225 fired right up without a hitch. it took a couple minutes longer for it to idol with the choke off but it didn't make it any harder to start. And my garage is totally unheated and isn't attached to the house so it gets as cold in there as it does outside... lol
