Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
Thread: Big Red front rack LED lights - Anyone have any pictures of what they have done?
    Sep 2011
    New Castle, PA
    1,134
    I thought that LED's had overheating problems unless they have a heat sink, so a good thing would be to run for like an hour and see what kind of heat they are making. The heat is not from the light produced (like an incandescent) but rather is at the base and behind the bulb. Get back to us if you could test them like that, maybe riding (air flowing) and sitting (stagnant air)
    Nice BR btw!
    Gone:
    Feb 2013
    Fort Wayne, Indiana
    225
    Quote Originally Posted by rg97 View Post
    I thought that LED's had overheating problems unless they have a heat sink, so a good thing would be to run for like an hour and see what kind of heat they are making. The head is not from the light produced (like an incandescent) but rather is at the base and behind the bulb. Get back to us if you could test them like that, maybe riding (air flowing) and sitting (stagnant air)
    Nice BR btw!
    Thank you. This is the back of the LED. Not sure that it is a heat sink, but it appears to be used as one. What do you think?Click image for larger version.
    Sep 2011
    New Castle, PA
    1,134
    Yep thats a heat sink (as long as its metal). You're fine.
    It should be aluminum, IDK if it's just me but it looks plastic in the picture.
    Gone:
    Feb 2013
    Fort Wayne, Indiana
    225
    Yes it is metal. They are nice and heavy duty. can't wait to get a video while riding with and without them on.
    MN
    3,263
    I have these same lights in the round version, they are a solid heavy block of finned aluminum. I have been using them for almost two years now, moving, sitting still, they get warm but never overly hot. Really good lights for the money.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Feb 2013
    Fort Wayne, Indiana
    225
    Quote Originally Posted by kb0nly View Post
    I'm very impressed so far.
    MN
    3,263
    The funny thing is Hella is now rebranding them and selling them as their own. They are not Hella made, they are made by one of the large led light manufacturers in China. So far i haven't had any issues with them. I have a 18w round flood version of these lights on my walk behind snowblower, thats been on there for four seasons now and takes quite a beating from vibration when running. I have been very impressed with their quality.
    I added a 18w to the back of my 200ES for plowing, needed some backup light, about a week ago and it sure makes it nice working in the dark. I plan on getting some more of the 27w floods for my Jeep, need some rear facing light for working. Would be nice to have some cargo lights for when i am pulling a trailer. Maybe wire one into the reverse circuit as a backup light, etc. They are so affordable, i have got them for less than $30 each on eBay.
    Feb 2013
    Fort Wayne, Indiana
    225
    You should post some pics. I am thinking of putting one in my trailer as well. I am about to buy a triangular tongue box and I think on the inside of the box I will add a switch and have one light in the bed of the trailer and one in the inside of the box. I have a single stage snowblower or it would have one also. I do have a 33" walk behind mower that I end up finishing the neighbors yards at night which means thats a perfect excuse to mount a couple on it for more light. Who knows where they will end up next the pair on the front of my big red were $50 shipped.
    bg77 is offline New to the board Arm chair racerNew to the board
    Sep 2013
    Foley AL
    11
    not the best pic but you can see my LEDs and where they are mounted on the front of the factory rack.
    MN
    3,263
    Here is the pair of 27w units on my 200ES, one is a 60 degree spot and the other is a 90 degree flood, makes for a nice combo and a larger lit area in front. I don't have a pic of the 18w on the back yet, i just got it done last week and its just been to dang cold to go out and snap a pic. Might have to do some plowing tomorrow though so then i can get a picture of it in use.
Name:	2012-11-16 11.50.31.jpg
ID:	184943Click image for larger version.
Name:	2012-11-16 11.50.37.jpg
ID:	184944Click image for larger version.
Name:	2012-11-16 11.50.47.jpg
ID:	184945Click image for larger version.
Name:	2012-12-07 10.01.23.jpg
ID:	184946Click image for larger version.
    Here is the 18w version on my walk behind snowblower, its an old 73 Craftsman 28 inch cut, has the extra drift chipper above the main auger, does great on the deep stuff, actually even better than my big lawn tractor blower because this old Craftsman is chain drive from the motor to the blower and augers. It has a centrifugal chain clutch on the motor just like a go kart motor setup. Thats the main reason it goes through stuff my other blower cant, the other one will get too much of a load on it and the belts will slip, on this one it will go until the motor dies. I repowered it with a new 7hp DuroMax motor i got off ebay, its a clone of the Honda GX series motor. The original Tecumseh motor was getting weak and nearly due for another overhaul so i decided it did enough. Plus i was able to add a battery and electric start, turn the key and go!
ID:	184948Click image for larger version.
ID:	184949Click image for larger version.
    Feb 2013
    Fort Wayne, Indiana
    225
    These look good. I am going to redo what I have on the back rack of my big red just not sure what I'm gonna out on it yet.
