Results 1 to 3 of 3
Thread: Replacement lighting coils, which are better OEM or aftermarket?
    Nov 2013
    Central Missouri
    70
    I'm going to replace my lighting coil on my ytm200ek, I keep getting weirdness fromit as sometimes it works and other times it doesn't, ohm meter gives flacky readings so im not sure if it's the wires or the coil it's self so im just going to replace it.
    Which are better, the oem nos or the aftermarket replacements? I intend to replace the charging coil too while I have it apart? Is the higher cost of Yamaha NOS worth the extra expense or are the cheaper ones ok?
    Nov 2013
    Central Missouri
    70
    Ah come on, no one here has had replace a magneto coil??
    Pacific NW
    4,255
    No answers?
    Is the whole midwest still without power and frozen?
    Everyone out riding?
    See if you can get the search key to work.
    I usually read all posts that relate, even if it's not my particular machine.
    Fastest way to get all the info ever posted, too.
