I own a custom coating company so I usually do these little 70's once in a blue moon and sell them at car shows. is the case cracked or is just a piece of the case broke off
1985 Kawasaki Tecate 250 with kx 500cc motor
1985 Honda ATC 70 custom built with lifan 125cc
1985 Honda ATC 70 custom powder coat slight mods
1985 Honda 250sx
Yamaha zinger 90cc 2 stroke
1985 Honda 250sx custom green and black build
1985 Honda 200x
I believe it is busted. I have never removed the entire motor from the box. When it was sent to me it was disassembled. I never took the motor out of the box. I just carried it over to the garage and set it on the shelf. Pretty sure the carb is missing. That shouldn't be much on eBay.
Current rides
Taurus 650 (green)
85 250es big red
82 ALT50
82 ALT50
71 QA50
93 TRX 300 FW
after seeing another thread about flat track racer I think that's what I may make this into
1985 Honda 250sx
1985 Honda 200x
Do you know who makes the chineese motor. I have a couple laying around with other problems. The flywheel side may be good on one of them. But if you are doing the work the 140 is a better motor.
Trikes:
1985 ATC 70 mod to 184cc
1984 ATC70 mod to 124cc
1983 ATC 70 Xmas restoration
Quads:
1986 TRX 250R
2002 TRX 400EX
2- LT80 for the kids
1986 LT 50
The cover says monster joe on it. I have the Lifan 140 in mine. Had to stretch the frame for it. 125 should fit in stock frame.
Current rides
Taurus 650 (green)
85 250es big red
82 ALT50
82 ALT50
71 QA50
93 TRX 300 FW
A lifan 125 fits fine. I'm putting one in a 70. Also have a 70 with a Honda 110 in it. Love the hi/low gear selection.
'86 Honda Big Red 250es
'85 Honda 250sx
'87 Honda 250sx
'85 Honda Atc 70
'83 Honda Atc 70
'00 Honda Trx 90 (sons ride)
atc70/110
The only reason I'm not using it is I am building a stroked, big bore 90 engine.
Current rides
Taurus 650 (green)
85 250es big red
82 ALT50
82 ALT50
71 QA50
93 TRX 300 FW
Id like to just build a stroked 70 stock motor. Like 108cc maybe? Old time youll have to stop down and the shop sometime. Im undecided about a lifan or just stroking a big bore 88cc
1985 Honda 250sx
1985 Honda 200x
Ive decided to go with the piranha 140cc. Just deciding how I want to machine the hubs and spacers
1985 Honda 250sx
1985 Honda 200x
Havent had much time lately with getting the powder coating done. Working on the frame and forks and hubs right now
1985 Honda 250sx
1985 Honda 200x
Got most of it powdered. Installed bearings and seals in rear and stem also. Hitting motor woth some purple powder then ill be installing that tonight probably. Gonna post pics soon. Been swamped at work havent had time to hop on the computer
1985 Honda 250sx
1985 Honda 200x
Yes I saw those! Id like to get some but then I would also need 4 bolt wheels amd tires to go along. Unless I can find wheels that fit stock tire size... maybe spanglers
1985 Honda 250sx
1985 Honda 200x
I buy my Aluminum wheels from Sterdy Products. They are the only aluminum 7" rim I have found that will let a 4 bolt hub fit in the bell of the wheel. The G-Force hub just barely fits. These rims come in the 3 bolt pattern, I drill the 4 bolt pattern into them. I like running the stock type tire's on the 7" wheel so I get great floatation in the sand.
