250sx help right side crank case
I took apart the right side crankcase because it had a crack in it. Cleaning it back up and trying to install it. Beside the reverse and neutral switch is a spring on a arm. Not sure what position it should be in but if someone has a pic or link please help.
My clymer manual has dink all in it
Thanks for your help in advance
i will in a bit. i have lots of SX eng pics
I've got it all apart in my garage scratching my head. Does the spring lock the arm facing up?
Here ya go. Its just a stopper for the shift drum to keep the shift drum from going in to rev until the left side is lifted up releasing the shift drum. Just use a small screwdriver to walk the end of the spring in to the case.
That's awesome thanks for the fast help.
Cheers
Anytime Brother. That's why we're here. Don't forget to leave the dipstick out when you put the cover back on.
I forgot to when I removed it. I got all happy once I removed all the bolts lol
Its a pain i n the ass but looks like u got the advice u needed. Good luck getting the right screws in the right hole on your first try. I think i will label them next time
//ArrowChat Integreation Code
