Results 1 to 11 of 11
Thread: 85 tecate rescued needs reassembled
    florida
    186
    I just picked it up. has new plastic but bike is in boxes, always wanted one. did some trading so I have no money in it so far. has dg pipe stock carb and a flat slide also. will get some pics up by the weekend, will definitely have questions when I get everything cleaned and powder coated for reassembly.
    STL
    3,560
    congrats, those first gen tecates are pretty cool! looking forward to some pics when you get them up. And there are alot of threads around here with info about rebuilding them
    florida
    186
    do any other model flywheels fit these motors? off kx maybe? going over parts and no flywheel. new stator thou.
    Sep 2005
    MICHIGAN
    2,027
    florida
    186
    thank you for the research, you did. great info
    Jan 2013
    minnesota
    5,911
    Hello;
    I don't know if the KX flywheel will fit over a KXT stator. nd4spd or someone else can tell you. You can also get new aftermarket parts from the link below.
    http://www.rickystator.com/
    A lighter flywheel like the KX is not recommended for recreational use.
    It will reduce traction, increase the engines "toggle switch" powerband feeling, cause it to stall easier when braking with the clutch still engaged and make it a bit more difficult to ride in the lower rpm range.
    Sep 2005
    MICHIGAN
    2,027
    All I use are KX250 flywheels, stators, and CDIs. Faster revving and less torque but everyone has their opinion. I just read a guy say he loved the KX setup in the heavier KXF four wheeler.
    You cant mix any of the above mentioned parts between models KX and KXT, they are always best used as a set.
    86 T3
    84 T3
    86 KX250
    florida
    186
    ok thanks for clearing that up, I am sure I will have plenty of questions for you. as I get into this trike
    florida
    186
    here are some pics. have tecate 4 parts also kips motor apart. some plastic pieces, and exhaust. also pro circet pipe for trx250r.
    she definitely needs help. frame and a few pices are gone to powder coat already.Click image for larger version.
    florida
    186
    as soon as I find where my pics went I will put the rest up in an hour or so
    florida
    186
ID:	185807Click image for larger version.
ID:	185808Click image for larger version.
ID:	185809Click image for larger version.
    here is a few pics of what it looked like to start
