86 200x atc
Im new to the cite but have always been able took look up good information on here. I have a honda 1986 200x ATC THREE-WHEELER, and the clutch went out. I was able to buy a clutch kit and install it with no problem. However, I put the cover back on and tightend everything up, started it up and went to put it in gear and the clutch had no tension. I have ajusted the cable and have taken it back apart to see if I did something wrong and still can not figure it out. It will go into first and second gear but the clutch will not operate to allow it to go into any other gears. Any help would be great!
I don't have an answer for you but stick tight , you will get the answer you are looking for
I just wanted to say , Welcome
Did you soak the clutch fibers in oil before installing ?
//ArrowChat Integreation Code
