Results 1 to 15 of 18
Thread: run away 2 stroke
    Aug 2013
    british columbia
    10
    run away 2 stroke
    Well heres a interesting dilemma, just got my kxt 250 running, was sitting there idling when it revved right out by its self, to the point the kill switch wouldn't shut it off! Had to pull the pug lead....wow... what could cause this? Any idea's?
    Pacific NW
    4,255
    Hi and welcome.
    Try the search key with the words
    "death rev"
    Apparently 2 strokes can run like that without spark
    or kill switch doesn't kill it.
    Most opt for stalling them in gear.
    All I have 2 stroke is a chainsaw but there should be every answer to all your questions on here.
    emmie357's Avatar
    emmie357 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2013
    Upstate NY
    214
    Could be an air leak causing it to run lean.
    May need to be leak tested.
    84 YTM200E "yamahauler"
    85 YTM200
    85 KXT250 Tecate
    Jul 2013
    Vancouver bc
    37
    Where in bc are you
    Aug 2013
    british columbia
    10
    Im in Christina lake
    Apr 2013
    snyder texas
    456
    my 93 Polaris trail boss 250 was doing that right after I rebuilt the motor one crank seal must have got damaged when I put it together changed both seals helped a bunch but then would take a long time to return to idle found trash in pilot jet now it runs great
    Apr 2002
    s.w. michigan
    6,498
    When 2 strokes start starving for fuel they rev wayyyy up. If it was "dieseling" from being hot (don't sound like yours was) pulling spark plug lead would have no affect. Had it happen on a Polaris scrambler at TrikeFest a few years back, had to shut fuel off and let run out of gas.
    Or, air leak as suggested.
    emmie357's Avatar
    Jul 2013
    Upstate NY
    214
    When it happened to me it was a leaking crank seal.
    85 YTM200
    85 KXT250 Tecate
    glendive, montana
    1,822
    it is definitely a lean condition somewhere, time to tear into your fuel delivery and all your seals to find the problems. I would do a leak down test on it as well.
    Jan 2013
    minnesota
    5,911
    If you're not sure how to do a leak down test, check out the video below. It also shows cheap tools you can buy to do it with.
    You obviously need to remove the flywheel and clutch cover to check the crank seals.
    If you take the parts off, a shop might do it for around $60.00.
    http://www.youtube.com/watch?v=zdq7NRcUIp8
    STL
    3,560
    Clogged pilot jet can do that, open the throttle wfo or flip the choke up it will die right away. Clean that carb and go buy an inline fuel filter! I had my 500r do it at trikefest 2013 and once more at the badlands. Give it full throttle it will die.
    Aug 2013
    british columbia
    10
    Thanks for the info gonna leak test it on Monday!
    Pacific NW
    4,255
    Quote Originally Posted by jeswinehart View Post
    Oh, you mean like the old gas powered airplanes?
    .o49 little engines with a glow plug?
    Battery to glow plug, get it started and it would run without glowplug and you knew when it was running out of gas because it would roughly double in rpm's for 10-20 seconds before it ran all the way out of fuel.
    Might that be considered a 2 stroke diesel type of definition?
    Pacific NW
    4,255
    I wonder why I've never experienced this with any of my chainsaws.
    and I've had saws in almost every state of condition and for decades.
    ...just trying to understand
    Apr 2002
    s.w. michigan
    6,498
    Quote Originally Posted by tri again View Post
    If you get them hot enough,,,, just below the seizing temp,,, you will experience it.
