Results 1 to 15 of 24
Thread: Picking up a 89 trx300 2wd....thoughts?
    Mar 2011
    Red Lion pa
    1,542
    Guy at work sold his place in the mountains and no longer has a use for it. Been looking for something as a starter to get the wife to ride with me. She has no desire to hop on 3 wheels (they're dangerous! ), but is willing to try 4. Anyway, he's 2nd owner, 1st owner works with me as well. Garaged or "shedded" all its life. In great shape and plastics are not all faded. Runs and shifts great. Just needs a battery. $700, also got 4 helmets and a chest protector. So how did I do price wise? Likes, dislikes, quirks of this model? Any input is welcome!
    86 honda big red
    85 250sx
    82 250r
    86 klt 185 black (project)
    86 klt 185 red
    85 klt 160 (Floyd)
    85 klt 110 X2 (projects)
    86 klt 110 X2
    84 klt 200
    84 atc 70
    DUCKSTER!
    Oct 2013
    Wherever I May Roam
    3,757
    I think it looks great for that price! Can't beat knowing the previous owners too, good score!
    6,808
    Great machine and even better price .
    Feb 2013
    chicago il
    505
    worth it for price, especially with all the extra pieces. those bikes are real strong for being 2 wd.
    Trikes: All Honda: 84 250r, 85 86 and 87 250sx, 84 and 85 125m, 79 82 84 and 85 110's, 73 us 90 and 77 atc90, 75 atc70
    Cycles: Honda: 71 cb100, 78 cb750 coming soon cb750 trike. Yamaha: 67 yds 3 (250cc, 2cyl, 2 stroke), 82 750 SECA
    Other toys: Chenoweth VW sandrail dune buggy, old race go kart, racing mower, 76 Arctic Cat Pantera 440 snowmobile
    KEEP IT ON ALL 3 OR AT LEAST 2 AT A TIME
    NEPA
    7,051
    Unreal. If it doesn't pan out Mike. Please give me 1st crack at it. You did REALLLLLYYY good. Wow. Drop all the oils,clean/oil the filter,adjust and lube everything and that is ready for the next 30 years. I guarantee that doesn't even need the valves adjusted. Very nice find.
    Mar 2011
    Red Lion pa
    1,542
    Here is the rest of the booty. 3 HJC 1 old school and a Thor chest protector.
    86 honda big red
    85 250sx
    82 250r
    86 klt 185 red
    85 klt 160 (Floyd)
    86 klt 110 X2
    84 klt 200
    84 atc 70
    DUCKSTER!
    6,808
    The weak link on those is the metal gas tank , that one looks great .
    Dec 2003
    303
    Great looking machine and a fantastic price! That one looks like it's been babied. Those models are bad about getting water in the rear diff, but other than that should run forever.
    -Chad
    NEPA
    7,051
    And the starter,and one way bearings,and the diffs,and the rear brakes. But no worries on this one )
    MNhondaguy's Avatar
    MNhondaguy is offline At The Back Of The Pack Arm chair racerFirst time rider
    Sep 2013
    fergus falls, mn
    203
    A lot of those around here. It is probably the only quad I would ever own. My brothers brother in law has one and he put new arctic cat rims and tires on it, I think 27" or bigger. Has a plow on it and it just doesn't stop working. Pulls the fishhouse out no problems. Amazing little thing for only being 2wd.
    83 ATC 200E(X) Big Red
    My YouTube- http://m.youtube.com/user/mazdarattiman
    My bros (hoopster3030) YouTube- http://m.youtube.com/user/hoopster3030
    Jan 2011
    Brazil, Indiana
    2,087
    I have the 4X4 version of that. It is a great quad. I use mine for plowing snow and mowing. image.jpg When the battery needs replaced I'll show you a cheap truck to get a bigger power reserve and more cranking amps for a third the price of a new battery.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Mar 2011
    Red Lion pa
    1,542
    Thanks for all the replies guys!
    Quote Originally Posted by hoosierlogger View Post
    Does need a battery so hook a brother up
    86 honda big red
    85 250sx
    82 250r
    86 klt 185 red
    85 klt 160 (Floyd)
    86 klt 110 X2
    84 klt 200
    84 atc 70
    DUCKSTER!
    Jan 2011
    Brazil, Indiana
    2,087
    Put a lawn mower battery in the trunk. You will need a 6" extension for the negative cable to reach that far. But you can't beat a 325 CCA battery. I did it to mine a few months ago. Last week when it was -18 degrees out overnight it started. I doubt the stock size battery would have done it.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    May 2013
    Henderson, Tx.
    977
    Great quad!!!!! We have 3 of them in the family. All 4x4. Dad's 99 still has the original battery!!!! Fantastic machines. Only quirks or issues I can think of is the electrical junction box under the front fender. It has a 10mm head bolt that holds it shut, and there is a white connecter inside (among others) that can come loose and it won't start. Just have to reroute it inside that box. It is actually stated in the Clymer manual.
    Other then that just change the engine oil, diff oil, service or replace the air filter, new spark plug, adjust the clutch and down the trail your go. If there is no valve train noise I wouldn't even bother to adjust the valves. Like said previously, it probably doesn't even need it! They hold an adjustment that well.
    I would change the rear brake drum cover's seal, and large o-ring that goes on the backing plate. There is a method that I use to reinstall that rear brake drum cover so water does not get in. Have not had any water issues on our 3 since I started doing it.
    Mar 2011
    Red Lion pa
    1,542
    Ended up popping for this battery on ebay (same brand as the ones I got for the SX and BR)
    http://www.ebay.com/itm/400635594484...84.m1439.l2649
    At $35 figured can't go wrong. Would like to keep the trunk open to carry necessities if needed (like the heavy duty tow strap he's leaving in it). Has fresh oil and carb kit. Filter is good but needs a good cleansing and oiled. When I asked about the differential he said he hadn't touched it, so that will be the first task. Very familiar with this this myself with having the SX & BR. Oh and in the pics the right side cover is missing....has that too, just took it off so he could kick start it since battery is dead. I'll get better pics in the daylight once I get it home. Probably this wkd. First quad for me. I'll be careful, I hear that extra wheel makes it even more dangerous!
    86 honda big red
    85 250sx
    82 250r
    86 klt 185 red
    85 klt 160 (Floyd)
    86 klt 110 X2
    84 klt 200
    84 atc 70
    DUCKSTER!
