Results 1 to 11 of 11
Thread: lowering 350x
    fcf35's Avatar
    fcf35 is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2013
    arkansas
    228
    lowering 350x
    Looking for a quick way to lower my 350x.I have a nice set of some Hoosiers and after putting them on I had to figure a way to lower it.I want it flatrack low.I basically wanting to know if there's a quick way to lower it without alot of money.
    3-350x
    85 250 Bigred
    85 250sx
    85 250r
    Sep 2011
    New Castle, PA
    1,134
    Set your preload low and bring your forks up through the trees. I've seen flat track bikes with a tie strap going from the swinger carrier to the grab bar also. You can do that if the back end still isn't low enough from lowering the preload
    Gone:
    fcf35's Avatar
    May 2013
    arkansas
    228
    Anyone know of a different shock off of something else that would work?
    3-350x
    85 250 Bigred
    85 250sx
    85 250r
    Jul 2012
    Joplin, MO
    597
    Tie strap works and cheap.
    fcf35's Avatar
    May 2013
    arkansas
    228
    I have a spare spring and I thought about doing the redneck lowering kit and cutting some off the spring.I'm not gonna be jumping it but I want atleast a bit of cushion.
    3-350x
    85 250 Bigred
    85 250sx
    85 250r
    Mar 2013
    Southern Wisco
    96
    I lowered by taking out the spring spacers out the forks and dropping the forks 3 inches. The rear I just backed the preload off til the spring started to come loose. I was extremely surprised how much the rear suspension still functioned very well and should be low enough for your needs as long as you have an axle/spacers.
    fcf35's Avatar
    May 2013
    arkansas
    228
    The preload trick works good.I think I still want to strap it just to keep things snug.
    3-350x
    85 250 Bigred
    85 250sx
    85 250r
    1,641
    If you are lowering to screw around the strap might be okay.If you are entering a event it may not be allowed.Google search lowering a 350x.You will see something like "Gerauld's 350x".That is what I do for ice racing.
    C.J is offline Just Too Addicted Arm chair racerJust too addicted
    Central, Louisiana
    639
    Quote Originally Posted by jays375 View Post
    Is this the link you're talking about?
    www.bob2000.com/atc350x.htm
    too many bikes to count. too little time on hand.
    1,641
    Yes.I added a spacer in between on the shock also.
    How many inches do you flat trackers want it lowered in the rear??
