Results 1 to 12 of 12
Thread: 350x swingarm extension
    Jun 2013
    Southern Indiana, United States
    140
    Can anyone give me any advice on where to cut the swingarm and how thick the steel is and how long I should extend it? I want to extend my swingarm, and don't know how much it would cost. I can cut and weld
    Myself but how much for a new chain and brake line? Any other problems I should worry about?
    350cc's of Pure Adrenalin'
    '85 350x
    '85 Big Red 250
    Sep 2011
    New Castle, PA
    1,134
    Double post
    Look down!
    Gone:
    Sep 2011
    New Castle, PA
    1,134
    I cut my swingarm between the shock mount and axle carrier on my 200x, then I got some 2" long tube the right size and thickness. TIG welded everything together and just yesterday welded some fish plates on the side for added strength.<br>Your best bet is to drill a 1/4" hole in the swinger near where you're going to cut it and measure the thickness using a depth mic on a set of calipers. My tube for example was 60mm x 30mm x 2.30mm rectangular tube. The 350x will be a different size. The company I ordered from sent me a free 6" sample of the tube and that was all I needed.
    http://www.3wheelerworld.com/showthr...and-weld-pics!
    Gone:
    Jun 2013
    140
    Quote Originally Posted by rg97 View Post
    how much was the metal u ordered.? Is sleeving a must? do I have to have an extended axle?
    '85 350x
    '85 Big Red 250
    Sep 2011
    New Castle, PA
    1,134
    The company I ordered from sent me a 6" free sample. I cut it into three EXACT 2" sections and used two of them for the swingarm (one for each rail), the third is a backup. (my swingarm is a +2)
    Sleeving is very strong and works well and if I put in my opinion I'm going to get tore up like I did in my thread. I do not think that sleeving is a MUST, but you gotta remember you have 150cc more than my bike. I recommend it, but can it be done without it? yes.
    Extended swingarms and extended axles work well together but it's not a necessity.
    Gone:
    Jun 2013
    140
    so other than welding tools and such, your extension was virtually free?
    '85 350x
    '85 Big Red 250
    Sep 2011
    New Castle, PA
    1,134
    Yep!
    I had to use the BIG bandsaw at work to cut the swingarm in half precisely, but other than that 100% free
    You may want to send a PM to KASEY, he does a lot of fabrication work with complete bikes and does very well with swingarms
    Gone:
    Jun 2013
    140
    I wonder how much he would charge to extend mine. I am wanting the badass extended look, and width,
    Without buying a 350 dollar axle if you see what I am saying.
    '85 350x
    '85 Big Red 250
    Sep 2011
    New Castle, PA
    1,134
    Extended hubs work well for width. Some are 2" extra on each side, so thats the same as a +4 axle
    I dont know if Richard (KASEY) will do it. Idk if he does work for other people. Worst case scenario you ask and he says no.
    Gone:
    Jun 2013
    140
    I'm trying for a new look. Extended swingarm, wheel spacers/extended hubs, new seat cover, new fork boots, new hand grips. Want to make my X look amazing. Trying to figure out different ways of doing so.
    '85 350x
    '85 Big Red 250
    Sep 2011
    New Castle, PA
    1,134
    It all depends on how much $ you want to throw at it
    Any pics? i can point stuff out
    Gone:
    Jun 2013
    140
    All I have at the moment
ID:	184639Click image for larger version.
ID:	184640Click image for larger version.
ID:	184641Click image for larger version.
ID:	184642Click image for larger version.
    '85 350x
    '85 Big Red 250
