Results 1 to 7 of 7
Thread: Newbie Needs Help
    Jan 2014
    Gulf Coast Texas
    4
    Newbie Needs Help
    I am trying to get my 1985 250 ESin good condition once again. Finally have some time. Yesterday, I installed a carb rebuild kit. I am by no means a mechanic, but I try. Anyway, got it all back together and running, but gas is pouring out of the overflow hose. Stupid question, I know, but is there supposed to be an o ring in the float needle chamber, for the float needle to seat on? Please forgive my ignorance.
    Oct 2013
    Wherever I May Roam
    3,757
    No. You may have the float too high, or the needle is sticking open, or there's a piece of crud holding it open. Or you got the wrong rebuild kit. Try the old float needle.
    Oh ya and
    Jan 2014
    Gulf Coast Texas
    4
    Thank You
    Thank you for the reply. My Brother In Law said the same thing you said. He said he has often got the wrong needle in rebuild kits. The float is a plastic float, non adjustable, but I think it was working before I got into it. I need to take it back down anyway, as my choke (Honda calls it a starter valve) is not working correctly anyway. I guess I'll buy the kit for it, as the one that is in it now does not have the "O" ring on it, and the needle has some slop in it and I do not think it is going back down the hole. Once again, thanks for the reply. As I said, I am by no means a "Wrench", but with todays prices, I better become one quick. I'm trying. Thanks.
    Jan 2011
    Choctaw, OK
    2,755
    here is a tutorial on rebuilding these carbs. Try this first, tap the bowl with a screwdriver handle or shake the trike real good. It will help center up the float valve. Not unusual for these carbs.
    http://www.3wheelerworld.com/showthr...54#post1257154
    Jan 2011
    Choctaw, OK
    2,755
    And no, there is no oring for the float valve seat. The float valve has a rubber tip.
    Nov 2013
    Benson, AZ
    147
    If the float is not adjustable, it may still have sunk. I only mention because not all rebuild kids come with a replacement float. Of course, that's not the root cause of your problem at hand....most likely float needle/seat related. Try the original needle as others have said. After that, make sure the float height is correct before starting in on jetting.
    Jan 2011
    Choctaw, OK
    2,755
    One of three things is happening
    The float is no longer buoyant. See if it floats in water. Is yes, then the float is ok
    The float valve seat has junk in it. Shoot some carb cleaner in the hole and blow it out real goo.
    The float valve is not centered up. Tap the bowl with a screwdriver or shake the trike real good.
