Results 1 to 15 of 22
Thread: They're multiplying ATC 70's
    Jan 2011
    Greene,Ia
    688
    last week got ahold of my first atc 70. its a 79. has the common bent frame, tank and carb were trashed, but ordered a new carb for it, and in the process of cleaning the tank now. ordered a new set of fenders for it. picked it up for $100
    today found another atc 70 and picked it up. got it from a chick that was tweaking pretty good. definitely on drugs. has sores,scars and scabs all over her face. was told this one ran. its a 85. overall better shape than my 79. frame is straight, fenders arent busted up, but the rear tires are too big for it, so they rub the fenders. pulled and pulled on it with no fire. asked lady who owned it if she had anything that i could siphon some gas from the tank and squirt in spark plug hole. she said yes, disappeared in her house, and came back out with a needle/syringe. lol. it did the trick the lil guy started right up and didnt make weird noises or smoke.gas cap is screwed, missing the rubber seal, so what did they do, they tried to seal the gas cap on with expandable foam lmao. they also painted the tank and both fenders with red house paint, i have no idea how to strip that off. she wanted 200, snagged it for $125 haha. loaded it, and immediately took off to a gas station to wash my hands. haha.
    im still in the air as to what i want to do, obviously i want one to build/restore for my daughter. obviously i could make a really nice one out of my 2. but then again for as rare as the 70s are in my area itd be fun to fix both.. i have some time to think about it. got them both dirt cheap, so its not hurting me to hang onto both
    2006 Yamaha Raptor 700
    2004 Kawasaki KFX700 V Force
    1985 Suzuki LT230GE(wifes toy)
    1985 Honda ATC 70
    1979 Honda ATC 70 (daughters toy)
    Apr 2010
    Indian Falls, NY
    1,289
    Nice score, here's hoping she'll clean up nicely. Chemical paint stripper might work, but I'm not sure how that would adversely affect the plastic underneath. First thing I'd do is to try and scrape off as much as you can, without severely scratching the plastics, and then pour rubbing alcohol in light amounts around the areas with paint and rub it with paper towels. If it doesn't immediately come off, then just wait a bit and then more when it dries. After you get the paint off give the entire thing a good wash. Hopefully that should work.
    Jan 2011
    Greene,Ia
    688
    ya i dont want to get too far into scraping, as from what it looks like the plastics are in decent shape
    1985 Honda ATC 70
    Apr 2010
    Indian Falls, NY
    1,289
    Best bet is to try the rubbing alcohol alone then.
    Jan 2011
    Greene,Ia
    688
    is rubbing alcohol even strong enough to cut paint?
    1985 Honda ATC 70
    Mar 2013
    Central PA
    2,362
    Geez, are those 22's?
    emmie357's Avatar
    emmie357 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2013
    Upstate NY
    214
    Some goo gone and a green scrubbing pad worked good for taking spray paint off plastics for me.
    84 YTM200E "yamahauler"
    85 YTM200
    85 KXT250 Tecate
    Jan 2011
    Greene,Ia
    688
    Quote Originally Posted by Ghostv2 View Post
    lmao, i thought the same when i saw it...
    1985 Honda ATC 70
    Jan 2011
    Greene,Ia
    688
    Quote Originally Posted by emmie357 View Post
    Some goo gone and a green scrubbing pad worked good for taking spray paint of plastics for me.
    this is house paint, and is on about 1/4 thick
    1985 Honda ATC 70
    Apr 2010
    Indian Falls, NY
    1,289
    Oh boy...then I don't know if anything will take it off.
    MN
    3,263
    Does the paint seem hard and dry or kind of soft and rubbery? Trying to determine if its Latex or Oil based. The Oil based usually feels harder, the Latex paint stays more flexible and rubbery. Either way a good first test is to take a rag and soak it in acetone, then lay the rag on the tank or fender, just let it rest and sit there a while, then come back in say 10-15 mins and see if it softened the paint up. If your lucky they went really cheap and its latex paint, once you get a start on it its easy to peel and clean off. If its oil based it might have a good bond down, especially to the gas tanks original paint. But the acetone soaked rag works great. You can also try some spray can paint remover just be careful with chemicals on the fenders since it can mess up the plastic, but the tank is easier since you can always sand it down and repaint anyway.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    emmie357's Avatar
    Jul 2013
    Upstate NY
    214
    If it's enamel/oil paint it could be a pain. You will need a strong solvent or paint stripper (be careful that it's safe for plastics).
    If it's latex/acrylic rubbing alcohol or windex may do the trick.
    Whatever you do, test it in a hidden spot like under the fender or seat (if those spots are painted) and be prepared to but some muscle into it.
    Don't even ask me what to do with lead paint... I've never messed with it (but hear it taste good).
    85 YTM200
    85 KXT250 Tecate
    Apr 2010
    Indian Falls, NY
    1,289
    That's a good one!
    Oct 2013
    Wherever I May Roam
    3,757
    You know you aren't supposed to feed those things after midnight......
    Feb 2013
    chicago il
    505
    my vote is build 1 for the daughter and 1 for you with a 125-150cc lifan or piranha engine. I have had good luck using paint stripper gel to get paint off plastics, without hurting the plastic. but you have to keep an eye on it. as soon as the paint starts to blister get it off there. a soft plastic bondo (body filler) spreader helps with removal. they probably got painted for a reason, so they probably wont be nice underneath, but you can repaint with the proper stuff. Any type of abrasive pad or scraping will for sure damage the plastic. but you might find they need sanded and painted anyway.
    Trikes: All Honda: 84 250r, 85 86 and 87 250sx, 84 and 85 125m, 79 82 84 and 85 110's, 73 us 90 and 77 atc90, 75 atc70
    Cycles: Honda: 71 cb100, 78 cb750 coming soon cb750 trike. Yamaha: 67 yds 3 (250cc, 2cyl, 2 stroke), 82 750 SECA
    Other toys: Chenoweth VW sandrail dune buggy, old race go kart, racing mower, 76 Arctic Cat Pantera 440 snowmobile
    KEEP IT ON ALL 3 OR AT LEAST 2 AT A TIME
