Page 3 of 7 FirstFirst 1 2 3 4 5 ... LastLast
Results 31 to 45 of 95
Thread: 1984 200x build with pics.
  1. #31
    lokisbuddy's Avatar
    lokisbuddy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    michigan, oscoda
    429
ID:	185710Click image for larger version.
ID:	185711 the old airbox tube replaced with stock thanks to Jsmay and the old 20lb grab bar I pulled off ordered prm grab bar.
    200x build
    My Feedback
    The world is broken up into two very different groups of people: there are those who like me, and those who can go to hell
  2. #32
    Apr 2010
    Indian Falls, NY
    1,289
    Are you planning on making this into a nice rider or?
  3. #33
    Sep 2011
    New Castle, PA
    1,134
    Man you work so much faster than me LOL, do you not have a job or something? You work super quick and it looks amazing, I'm jealous!
    It took me a week or so just to get the frame stripped down, and I can do my own blasting but I don't have a recycling system (i.e. a cabinet) so its not worth it to do the frame myself
    I'm looking forward to seeing this finished as it is incentive for my own X LOL
    Gone:
  4. #34
    lokisbuddy's Avatar
    michigan, oscoda
    429
    I plan on making a trail bike out of her ultimately she will get a cr 250 engine but for now just a trail bike. I have a 600 grizzly that needs tires and battery, a 700 grizz that needs new tires and tune up, a gator that needs rings , a cr 250 that needs rings a pipe and a boyesen rad valve and a kx 80 that needs paint and rings then after all that I ha 5 sl500s that need put back together. so engine will have to wait I put a lot of dough into parts cant wait till they get here
    200x build
    My Feedback
  5. #35
    lokisbuddy's Avatar
    michigan, oscoda
    429
    Quote Originally Posted by rg97 View Post
    Yeah I work but its seasonal.
    edit: I don't have a cabinet I just spray outside sand is 20 a bag used 3 bags.
    200x build
    My Feedback
  6. #36
    Sep 2011
    New Castle, PA
    1,134
    If you don't mind, what rust protector/primer/color/clear coat are you using? I really like that setup and your results!
    For the color I only need the brand because I am doing a different color than you are
    Gone:
  7. #37
    Oct 2013
    Wherever I May Roam
    3,757
    Lookin great man keep it up!!
  8. #38
    lokisbuddy's Avatar
    michigan, oscoda
    429
    dart inhibitor, house of kolor kosmic show klear and kosmic kolor urethane.
    200x build
    My Feedback
  9. #39
    lokisbuddy's Avatar
    michigan, oscoda
    429
    one thing I can say about this paint is make damn sure you get 0 moisture into the paint whether from gun or humidity this likes to orange peel like a mofo
    200x build
    My Feedback
  10. #40
    Oct 2013
    Wherever I May Roam
    3,757
    Also ambient temperature wherever you are shooting the paint will determine the amount of orange peel you are getting. Colder it is the worse it is.
  11. #41
    Apr 2010
    Indian Falls, NY
    1,289
    Any ideas of what you want it to look like when it's done before you swap the motor? I have seen a CR125 motor swapped in, that was pretty cool.
  12. #42
    lokisbuddy's Avatar
    michigan, oscoda
    429
    yeah when I get my cr 250 put in it will have a +2 swinger +2 axle other than that it will be as is except on a dif frame with motor mounts modded and it will have a moded pro circuit pipe. gonna be a lot of work. thinking liquid cooled not for sure. if I go liquid she will change drastically.
    200x build
    My Feedback
  13. #43
    Apr 2010
    Indian Falls, NY
    1,289
    I've never been a fan of extended swingers but the +2 axle might be cool. Will definitely be an interesting build for sure.
  14. #44
    lokisbuddy's Avatar
    michigan, oscoda
    429
    temp was no problem. even the floors of my garage are heated Click image for larger version.
ID:	185721Click image for larger version.
    200x build
    My Feedback
  15. #45
    Willamstown PA
    5,824
    looks like it should turn out way nicer then when you 1st got it. dont use 22s in the rear however, these bikes like smaller tires.
