Page 4 of 7 FirstFirst ... 2 3 4 5 6 ... LastLast
Results 46 to 60 of 95
Thread: 1984 200x build with pics.
  1. #46
    Sep 2011
    New Castle, PA
    1,134
    Also ambient temperature wherever you are shooting the paint will determine the amount of orange peel you are getting. Colder it is the worse it is.
    Thats why I'm waiting until spring until I start painting everything on mine. My garage isnt 24/7 heated but with the furnace and the turbo heater it will get around 60. And I have to blast outside so spring is nice for that as well. Black diamond, great stuff! I have been using HPA 80 lately and it is more expensive but the results are fantastic. It's main use if for sand in a waterjet so it is very fine but still cuts like a hot knife through butter
    Gone:
  2. #47
    Oct 2013
    Wherever I May Roam
    3,757
    looks like it should turn out way nicer then when you 1st got it. dont use 22s in the rear however, these bikes like smaller tires.
    +1 here----the difference in handling between 22s and 20s is pretty drastic on the 200x. I'm actually going to run 18s and taller gearing on the X I'm building now.
  3. #48
    Willamstown PA
    5,824
    I went 18's again, just alot funny on a 3wheeler with 18's
  4. #49
    lokisbuddy's Avatar
    lokisbuddy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    michigan, oscoda
    429
    I already have my tires and aluminum rims ordered 20x11x9 should be here next week. buttoning the motor up right now put the xr cam in and wiseco .20 over piston new bottom end bearings. will post pics later when im done.
    200x build
    My Feedback
    The world is broken up into two very different groups of people: there are those who like me, and those who can go to hell
  5. #50
    lokisbuddy's Avatar
    michigan, oscoda
    429
ID:	185802Click image for larger version.
ID:	185803Click image for larger version.
ID:	185804Click image for larger version.
ID:	185805Click image for larger version.
ID:	185806 got motor all ready to go just need 110 main jet. experimented with paint scheme on motor got front end back together painted metal around headlight. got my new shrouds, fender and grab bar.
    Edit: waiting on swingarm bearings and bolt and tires and my seat cover.
    200x build
    My Feedback
  6. #51
    lokisbuddy's Avatar
    michigan, oscoda
    429
    The motor paint is spray can but if it looks nice im gonna powder coat.
    Edit: frame In above pic is covered in saw dust from the table saw.
    200x build
    My Feedback
  7. #52
    Sep 2011
    New Castle, PA
    1,134
    You ordered the wrong front fender! That one is for an 86-87 X and will not bolt up unless you're running that front end.
    If you want that skinny fender look, the 85-86 250r fender bolts right up.
    Gone:
  8. #53
    lokisbuddy's Avatar
    michigan, oscoda
    429
    There are no holes drilled so I'm pretty sure it will bolt to whatever i want
    200x build
    My Feedback
  9. #54
    Sep 2011
    New Castle, PA
    1,134
    Well if/when you run into problems...
    Gone:
  10. #55
    Willamstown PA
    5,824
    86-87 fender will bolt up, holes are the same locations.
  11. #56
    Sep 2011
    New Castle, PA
    1,134
    This is an 83-85 Fender
    This is 86-87
    Definitely not the same bolt pattern, and I'm not sure if you can drill holes in the right locations because of the shape of the fender
    Gone:
  12. #57
    Oct 2013
    Wherever I May Roam
    3,757
    A Honda 86-87 fender will not bolt up, just like rg97 says, and shows
    However the Maier 86-87 fender does not come predrilled, just like lokisbuddy says
    It has been done.
  13. #58
    Sep 2011
    New Castle, PA
    1,134
    But really instead of doing guesswork for drilling that may not be easily compatible, you're better off returning the one you have (unless you cant return it then ignore this) getting a 85-86 R fender. They look pretty much the same. just my honest opinion.
    In white this is what they look like.
    Gone:
  14. #59
    Oct 2013
    Wherever I May Roam
    3,757
    The R fender DOES look really nice on them. However, it looks like Loki has a good handle on the technical work....nothing wrong with being different! I'm looking forward to seeing it work!!
  15. #60
    Sep 2011
    New Castle, PA
    1,134
    Yeah loki has some nice mechanical skill. I've got faith in him to do whats right lol. At this rate the trike will be done in a week or so!
    Gone:
