1983 200E Running issues! Help!
Well we just picked up an 83 200E for my buddy for 200 bucks. Its all complete but I have some issues. I cleaned the carb and It runs but it runs pretty poorly, It will not idle. I pulled the plug and it looks reallly rich, so I pulled the air filter off and it runs better but will still stall if you don't hit the gas. Another thing I noticed was that when you rev it the headlight dims, and when it starts to stall the headlight brightens way up. I am not sure if the running issue is electrical, or carb issues, but I know for certain that the headlight should not brighten when its stalling and dim when its revved, LOL. Also Im going to go through the front forks as there seized up. I do not see pinch bolts like my 250es at the top of the "triples." How do I pull the forks out?
Thanks in advance guys!!
1983 ATC 200x
1982 ATC 250R X2
1983 ATC 250R : Future build
1985 ATC 250R : Main rider
1985 ATC 363R Duner
1985 ATC 250R X2 : Future build
1986 ATC 250ES
