Thread: Are the front brake calipers interchangeable between 250r and 350x?
    Nov 2011
    Connecticut, USA
    50
    ^^^^^^^ That very question. I tried to do some searching on the forum but didn't find anything pertaining to that question. I'm seeing on eBay that 250r calipers are both more plentiful and inexpensive, so I'm wondering if they are the same caliper in terms of mounting to the forks?
    1981 Honda 185s
    1982 Honda 110 (junker under a tarp for now)
    1983 Honda BIGRED-185s Hybrid
    1985 Honda BIGRED 250ES
    1985 Honda 250sx
    1983 Kawasaki KLT250a
    Jun 2009
    Leander TX
    2,217
    As I recall from my 350X brake hunting - Yes and no.
    350X used 2 different calipers in 85 and 86 - one with fins and one without. The cutoff is roughly 85=finned and 86=not but it's not exact.
    They use different brake pads - one (non-finned) uses one pin to hold the pads in, the other uses 2 pins.
    The bracket must match the caliper.
    Looks like the 250R has different part numbers for 85/86 but the caliper is the same - I think....
    The 250 caliper should work on the 350X bracket for the finned caliper.
    The finned caliper is also found on various XR/XL motorcycles.
    The 85 350X front caliper and both 250R front calipers and the XL/XR calipers all use the same pad that has 2 retention pins.
    An interesting note - late 80s-90s CR front calipers use the same pad as the 86 350X non-fined caliper. I wonder if they'll mount on the 350X bracket and work on the 350X? I need a caliper and bracket for the front of my 86.
    model caliper bracket pad EBC PAD
    350X finned 45101-MG3-006 45110-HA5-006 45105-KA3-731 FA92
    350X not finned 45100-HA5-671 45110-HA5-671 45105/6-HA5-672 FA125
    250R finned 85 45101-MG3-006 45110-HA2-006 45105-KA3-731 FA92
    250R finned 86 45101-HA2-672 45110-HA2-672 45105-KA3-731 FA92
    Nov 2010
    Oshawa, On, Canada
    2,123
    I do know that 85 350x caliper works on an 86 250r aslong as you use the 250r mounting bracket. And vice versa.
    I have an 85 X caliper on my R.
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    I as well believe the finned caliper in 85 was different from the smooth in 86.
    I'd just simply check the part number at Service Honda....
    Blossvale NY
    4,563
    My brother is using a 250r front caliper on his 86 350x.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
