85 Honda 200x.
66mm 10.25:1 piston
Mild porting on head
Webcams 40b cam
2mm oversize Carb from an xr I believe, using xr intake boot.
supertrapp exhaust, 12 back pressure disks.
Moose Filter, airbox lid INSTALLED, with rubber snorkel on front of airbox removed
Okay, ive been dicking with tuning the carburetor on this thing for a wile now. Cant get it figured out, im starting to wonder if the carb is just too big. It runs amazing wide open, it starts and idles great, no backfire EVER. plug is good color. Jetting is 118 main, stock needle on 4th clip, 42 pilot.
I cant seem to get this bog out of it. You pin it from idle, in neutral, and it just Doesn't fire even once from the second you crack the throttle wide open to the second it completely dies, just like you hit the kill switch! If you choke it halfways? great throttle response, in neutral I remind you. However with the choke half on, when you start getting pretty high in the revs it starts to sputter, which is expected. So what should I try next? Ive had all the way from a 35 pilot in, to a 42. Doesn't really seem to make much difference. The needle doesn't seem to affect it no mater where you put it. Ive tried all sorts of different main jets, but it runs flawlessly wide open high rpm. revs REALLY nice and makes the nice dark tan plug color. You don't seem to notice it when riding because I like to keep it in the higher RPMs, but if I try to a slow wheelie from idle, I struggle a lot. What next?!
