Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 45 of 64
Thread: Honda line tachometer, canister repair.
  1. #31
    Apr 2002
    s.w. michigan
    6,498
    Apart and begining repairs
    Got a great start on housing repair.
  2. #32
    Lewiston, N.Y.
    1,477
    That looks awesome John!
  3. #33
    May 2009
    S.E. Michigan
    1,251
    Hey John!
    I think you may have shown it elsewhere, but I can't find it...
    How do you cleanly open up the tachs? Did you have the modified needle nose pliers to open the lip? I saw somewhere a fairly blunt set of needle nose pliers that had the tips ground in a special way to help open that metal ring.
    EDIT: Ok, so I actually read the first post and see the pictures... Can you get some closeups of the business end of those pliers?
    Double EDIT: I think you've got a good enough pic in the very first post. I see what you did there. Carry on with your normally scheduled program.
    Thanks!
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
  4. #34
    Apr 2002
    s.w. michigan
    6,498
    ruff in done
    Done a backer pour on the inside in white to marry outside bottom to inside for durabilty.
    Plenty of sanding to do while I wait on some tank parts to come in that I need to make molds of to repair this project as close to oem as I can.
    Attached Thumbnails Attached Thumbnails 20160301_203437.jpg   20160301_203520.jpg
  5. #35
    Apr 2002
    s.w. michigan
    6,498
    Got a loaner tach to prototype parts from
    I gotta admit, I was not expecting to receive a brand NEW tach to use for making a mold of the little round stand off's for the tach I am repairing. Holey crap, almost to nice to be handling !
    And also included was a rubber cushion that I need to make mold of so I can produce a couple of replacement ones that are missing from the mounting bracket.
  6. #36
    Lewiston, N.Y.
    1,477
    That....is....beautiful...
  7. #37
    Apr 2002
    s.w. michigan
    6,498
    and cute little molds can be made
    Done the round peg thingys differently then I originally thought to do them. And got the start of the pieces I need to make,,,,
    Attached Thumbnails Attached Thumbnails 20160305_204844.jpg   20160306_094521.jpg
  8. #38
    Apr 2002
    s.w. michigan
    6,498
    And another picture.
  9. #39
    Apr 2002
    s.w. michigan
    6,498
    About done with resin pours
    Done with resin pours,,, well perhaps a little touch up (?) as the wet sanding begins.
    The remaking of the 2 post turned out well. 1 solid pour. Inside + out side married together for optimum strength.
    Only thing left to do with them is to cut too length. Not sure if they need to be hollowed out some what like oem but if need be it is just a detail to do.
    Lots of wet sanding coming up ~
  10. #40
    Arizona
    495
    Outstanding work. Its looking great.
  11. #41
    Lewiston, N.Y.
    1,477
    Great work John! Love watching restorations
  12. #42
    Apr 2002
    s.w. michigan
    6,498
    Molds producing, sanding,,,, well its coming along
    The Mrs. took the little molds and had her way with them while I was at work () ,,,, she definitely nailed both spot on and is recasting a few extras for me.
    The canister sanding is coming along, kinda slowly but improving. I done 1 touch up and will need to do it again. I just can't get the last of the "witness" marks out unless I do a over pour,,, again
  13. #43
    Lewiston, N.Y.
    1,477
    Looks terrific John! I see that you poured into the canister as well - I assume this will strengthen the cannister making it less prone to future cracking?
    Additionally, I tip my hat to you and Mrs. S! Those spacers are top notch! Can't wait to see the finished product!
  14. #44
    Apr 2002
    s.w. michigan
    6,498
    Yes, the mounting area will be much less fragile then originally made. I have handle a small number of these tachs over the years and don't ever recall seeing a one of them with the little round plastic sealing cap that fits into the housing where main wiring loom pass's thru.
  15. #45
    NEPA
    7,051
    No clue lol,,but would spotting glaze cover up your witness mark? It looks like it would,but maybe doesn't adhere well enough?
