Results 1 to 2 of 2
Thread: 85 250r HOT RODS +4 Stroker Crank or just long rod?
    2hundredx's Avatar
    2hundredx is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2008
    Missouri
    392
    I picked up a motor yesterday off of an 85 250r. Had a spacer plate below the cylinder. Crank rod says hot rods and c.k. 109. Is there any way to tell if this is just a long rod or if it is a +4? The cylinder has quite a bit of port work. and it has a pro x piston that says hm25084 on the inside and 125 stamped on top. Looks to be an 85-86 style piston. Also has a cool head. Any info would help me out a ton. Thanks!
    My first 3wheeler- http://i290.photobucket.com/albums/l...ite200x002.jpg
    Current 3wheeler- 1985 250R
    "Your four wheeler must be fast 'cause you were haulin ass when I passed you on three wheels"
    Jan 2013
    minnesota
    5,911
    sure, one way is to simply
    put a coat hanger in the spark plug hole.
    rotate engine untilo its at bottom.
    mark the rod.
    rotate engine until its at the top, you can use the T timing mark for this.
    mark the the hanger.
    measure the distance.
