Results 1 to 15 of 16
Thread: 85 250es Big Red Electric issue
    May 2011
    The Granite State
    914
    my 85 Sped has not wanted to start as of late with the electric start when its cold. Half the time you press the button the solenoid doesn't even make that clicking sound. Has spark and fuse is good. Once you do start it (with kicker) and it warms up the electric start system will work all day no problem. Park it and next day same thing, just wont fire initially w/ the electric system when cold. Any ideas?
    86 350X ::: 85 250R
    Projects
    350x
    Come and Gone
    86 350x : 84 250r X2
    85 350x X2 : 84 200es X3
    83 200e : 78 ATC90
    Austin, Massachusetts
    1,591
    i'd bet you checked, but could it be your battery isn't holding a charge? once you kick it and the stator charges then it'll start all day. leave it over night and it drains? just a quick, simple thought.
    Wubba Lubba Dub Dub!!!!!
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    85 Yama 225DX - The Rental!
    150cc Piranha powered 70
    110cc Lifan 70
    82 70
    83 ALT 50 Trail Buddy
    88 Yamaha BW 80
    84 z50
    Jan 2011
    Choctaw, OK
    2,755
    Yep, sounds like the cold zapped your battery.
    Jan 2013
    minnesota
    5,911
    Hello Super350;
    When it’s cold does it sometimes turn over and sometimes within just a few minutes?
    I would check and clean connections at the battery, starter and relay etc.
    If it turns over more slowly when it is cold it might gave a weak battery. Even a new battery can go bad in 4 – 6 months if it is left sitting.
    A $3.00 battery hydrometer can tell you if its weak.
    A load test can also tell you if its weak.
    May 2011
    The Granite State
    914
    doesn't turn slower when cold, just doesn't turn at all. I didn't really check the battery as I'd be very surprised if it was dead, but then again I guess its possible. I wouldn't think its dead because its fairly new and I run this bike usually once a week anyways. And its not like it has time to charge at first start up, its literally right after started (3-5 mins) of warm up then the electric system will work
    86 350X ::: 85 250R
    Projects
    350x
    Come and Gone
    83 200e : 78 ATC90
    Jan 2013
    minnesota
    5,911
    how do you start it when the electric starter fails.
    try jumping the starter solenoid when the button does not work. if it turns over the connections are dirty or the solenoid is likely bad imo.
    honda4h's Avatar
    honda4h is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    ottawa ontario
    361
    my bike rolls over quick and fast you can kill and battery trying starting it. even boasting it. it's like the kill switch is off. i do have spark. the second you kick it. it fires up. it's 85 this is i issue i have had for some time i have 4 250 big red's and tried swapping parts etc with no success. other then the wiring harness.
    MN
    3,263
    Have you tried swapping the solenoid? On my 200ES this winter i had that problem, i thought it was the battery but the smart charger said the battery was topped off and its a brand new battery i put in this past fall. And its a nice AGM battery as well. Turned out the solenoid once brought in the house was doing the same thing on the bench until it warmed up, after it warmed up a bit then it worked fine. Replaced the solenoid and no problems. The solenoid has grease in it that can get really stiff with cold and age, and also the coil can get weak, expansion and contraction with temp changes, etc.
    Try a set of jumper cables and if it wont start with the push button take one side of the jumper cable and put it on the positive of the battery and then touch the other end to the starters cable terminal, does the starter spin now? If it does then its the solenoid, if not then i could be the starter is affected by the cold. Could be a bad winding or solder joint in it that makes contact again once its warmed up from the engine heat.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Aug 2012
    richmond nh
    647
    I will come over and check your battery today with a multimeter if you'll be around. I bet it's just a weak battery and doesn't like the cold. It was five below this morning.
    1,591
    Quote Originally Posted by roostin atc View Post
    Craigbulance to the rescue!! you gotta come up with some type of costume!
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    110cc Lifan 70
    82 70
    88 Yamaha BW 80
    84 z50
    May 2011
    The Granite State
    914
    hahaha...I have one but if the Craigbulance is in the area feel free....thanks for the input everybody!
    KB- I was thinking about the solenoid like your explaining but I figured it really didn't "warm up" seeing how its so far removed from the actual engine (heat source). Funny thing is, its actually been warmer around here as of late (25-30) and a month ago when it was in the teens she was firing up no problem
    I'll be messing with it today if I have time
    86 350X ::: 85 250R
    Projects
    350x
    Come and Gone
    83 200e : 78 ATC90
    May 2011
    The Granite State
    914
    looks like KB was right! I went out today and turned the key and pushed the button, nothing, no noise, movement, nothing.....I pushed it out into the sunlight an hour later pushed the button and the solenoid was clicking, another 20 mins it fired. So im thinking its a combo of the grease inside being cold and the solenoid in general getting weak.
    thanks for all the input guys, Im sure this thread will help someone out in the future
    86 350X ::: 85 250R
    Projects
    350x
    Come and Gone
    83 200e : 78 ATC90
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by Super350 View Post
    Post 6.
    May 2011
    The Granite State
    914
    ok you get gold stars too!
    86 350X ::: 85 250R
    Projects
    350x
    Come and Gone
    83 200e : 78 ATC90
    Jan 2013
    minnesota
    5,911
    I'd rather have the beer!
