Results 1 to 8 of 8
Thread: 350x clutch stiffness
    Jun 2013
    Southern Indiana, United States
    140
    I am almost near positive that my clutch is stock. it is pretty darn stiff too.. are the 350x clutches supposed to be stiff or not? is it my clutch hose or is it just normal? thanks
    350cc's of Pure Adrenalin'
    '85 350x
    '85 Big Red 250
    Basket may be notched a bit. I always run Barnett or OEM only; Also make certain the cable is newer /no kinks and LUBED!!
    Columbia
    5,131
    My clutch is smooth as silk! Pull it with your pinky finger and I have heavy springs. You'd be amazed how much a good cable affects the tension.
    Oct 2013
    Wherever I May Roam
    3,757
    Also might be a good idea to lube the cable.
    Sep 2011
    New Castle, PA
    1,134
    If it's the original cable you might want to spend the few bucks and get a new one. Your clutch and transmission will thank you...
    Gone:
    Sarnia, Ontario, Canada
    3,415
    Agreed, shouldn't be stiff to pull..
    But why it's stiff, worn basket, dry/seizing cable...only you could answer.
    Suggest to disconnect the cable from the clutch lever and see how the cables moves..should at least give an ideas where it's coming from and what your next move is.
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Jun 2013
    140
    Thanks. I just ordered some hellbound racing levers and a new seat cover. I'm getting the levers this weekend and I will check out the cable and get back to you guys. I had a raptor 350 and it was smooth. But didn't know about the 350x. Will riding it with it like this tear it up more?
    Oct 2013
    Wherever I May Roam
    3,757
    If it is dry/seizing then yes it can eventually break the cable. If the clutch basket is notched it will only get worse. Cable routing is also a factor in the lever pull stiffness.
    I would do as Doug suggests to check the cable movement.
    If it were me, and I had just ordered new levers, I'd probably get a new cable, but that's just me. Budgets do not always allow new parts, I understand that.
