Thread: Tri z help needed ( throttle cable )
    Jan 2014
    Edmonton
    50
    I have a moose aftermarket thumb throttle and need a throttle cable that will work with the stock round slide carburator. The factory Tri Z cable is discontinued. Does anyone know if a honda atc thumb throttle cable will work? Which ones? I really just want a part that I can go to the dealer a purchase without having to modify anything.
    85 tri z
    86 tri z
    85 dual z
    glendive, montana
    1,822
    look into 88 and 89 banshee cables. are you trying this on the 85 z or the 86 without the cable box by the neck??
    Abrams, Wisconsin
    739
    Check with motion pro, i think they make a replacement.
    86 250sx - old reliable
    another 82 110
    -gone but not forgotten-
    82? 110 - why did i sell it??
    84 225dx - meh, it was a pile
    Jan 2014
    Massachusetts USA
    782
    I have read in other threads that the 83-84 ATC250R cable is what you need. I will be needing the same thing on my Tri-Z resto when I get to that point. I believe Raffa is the one who answered this last time, try searching it.
    Jan 2014
    Edmonton
    50
    I will not be using a cable box and I have heard the same about the 83 250R cable but when I checked online these are also discontinued.
    85 tri z
    86 tri z
    85 dual z
    glendive, montana
    1,822
    time for ebay and see what you can find sometimes cheaper and other times more expensive.
