Page 1 of 8 1 2 3 ... LastLast
Results 1 to 15 of 112
Thread: An uninteresting 200x thread
    Austin, Massachusetts
    1,591
    I've searched the site, and there is an abundance of info on the 200x. Everything you'd ever wanna know. So, perhaps the questions that arise may have been asked an answered. Oh well. If it upsets you, move on the to next thread. Lots of drama on here lately, and, in the words of Sweet Brown, "Ain't nobody got time fo' dat!" I'm posting to learn, share some info, and lastly because i think a thread will motivate me a bit to get through the job.
    here is the back story. About two years ago, i picked up an 85 200x. It ran good, but she had been ridden hard and put away wet. just about everything on the wheeler was used up, abused, and in need of repair. The thing would smoke like nana at foxwoods on start up. Then it'd even out, and wasn't too bad. little puffs here and there if you ed the motor and made her work, but didn't appear to be what you'd notice from a "traditionally" smoked top end. I thought it was a valve seal issue. Also of note, and most important for this thread, the thing RIPPED. it was fast. I had no history on the trike and I had no way of knowing what had been done. Also, i'd never had another 200x, so a stock to stock comparison was not an option. It walked away from a 200es, and took a 250es, and 2 250sx's. (all stock) I suspect that the sx's may have caught up and passed if we had the running room, but i cant say for sure. Anyway, the x went good. Like i said before, everything on her was pretty roached. especially the rear bearings. tried to get one NH ride out of it last year and the bearings let go. paperweight. it was decision time for the little x. it was an overall basket case and the decision was to shelf it in lieu of other interests and projects.
    Flash forward a few months. A guy i ride with has his second kid and decides to thin his trike heard from 3 down to one. he's selling his 86 250r and his 85 200x and keeping his big red. i should have bought the r, and didn't. i bought the 200x. i got a great deal on it and it was in good shape. needed pads, which i did right away. also, the kicker was wearing out. if you're familiar with these engines, you know this is common, and splitting the cases is in your future. I knew i had the other engine, with good bottom end, so i was happy. took her on a few rides, hellhole, jericho MT, etc. etc. and everything was good. x#2 was not as fast as x#1. that was clear. it was, however, in good shape, reliable, and a decent survivor for an 85. then the problems began.
    the kicker problem was getting ever worse. early this year we took it to NH for the Super Dave Stunt Spectacular. It would start easy, and idle. as soon as it was warm, and you shut it off, you had to bump-start it to get it to run again. it wouldn't kick. if it sat and cooled, it'd kick over. it was weird. Then one day on a ride in walpole, it died. wouldn't start again. home to the shop with a weird, what i'll call, "intermittent" spark that seemed out of time. this is what i found.
ID:	186914Click image for larger version.
ID:	186915Click image for larger version.
ID:	186916Click image for larger version.
    the pin that holds the cdi into the cam had come loose. a small piece of the cam had broken off (it was stuck to the magnet). when i pulled the cdi, the pin and the rest of the broken cam came out in my hand.
    I had the other engine, so I swapped cams and CDI's and we were up and running again. (i didn't check closely to see if the cams were identical, but they seemed to be - more to come on this)
    x#2 was running fine, but it still had the lingering kick start shaft problem. the cold/bump start issue had been resolved with the cdi/cam problem. i think the reduced throw of the kicker, combined with the loose pin in the cam, wasn't generating the centrifugal force needed to advance the cdi and get the spark right. thats why the bump-start always worked. does that make sense? even if it does, that doesn't reconcile the cold start/warm start issue, which was also solved with the swap. i cant make sense of it.
    i'm snowed in this weekend, so i thought i'd deal with 200x #1. i've been thinking of doing an auto-x build for the bride somewhere down the road. i stripped it down almost to the frame. i still need to press out the swing arm bolt and get the shock off. but i took the engine out and dug into it a bit. interesting stuff.
    i popped the head off and immediately noticed a large gouge in the cylinder wall.
ID:	186908Click image for larger version.
ID:	186909Click image for larger version.
ID:	186910Click image for larger version.
ID:	186911Click image for larger version.
ID:	186912Click image for larger version.
    three little pieces of the snap ring that holds the wrist pin in place broke off and were trapped between the rings. ate up the wall and the side of the piston pretty good. the piston is/was a ProX. i've never heard of them, but i don't get out much. the crank and connecting rod seem good, as does the head, valves, and spings. i haven't measured anything, and i don't know it the engine was bored, or what other mods were done other than the piston. i would think that there are other upgrades. now, on to the real question. If i take the lower end from this engine, and swap the cylinder, piston, and head from the other engine, with a new tusk gasket kit, am i ok? remember, the cam in the other head was originally in this engine, so, it may not be stock. is that an issue? i'm not looking to win any races, i'd just like a nice reliable machine with not much more of an investment. if this engine has an upgraded crank, how can i tell without splitting the cases? will the throw be off if i go back to the stock head? are these questions making sense? in the interest of full disclosure, this is pretty deep in one of these engines for me. i've dabbled before, but this is new ground. i've rebuilt snowblower/lawnmower engines a bunch, but this is a bit different. any and all advise welcome. thanks for reading. sorry for the sideways pics. i'm left handed.
    Wubba Lubba Dub Dub!!!!!
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    85 Yama 225DX - The Rental!
    150cc Piranha powered 70
    110cc Lifan 70
    82 70
    83 ALT 50 Trail Buddy
    88 Yamaha BW 80
    84 z50
    Sep 2011
    New Castle, PA
    1,134
    If it had an upgraded crank (a stroker) then the rod would be shortened and the bottom of the piston would have been cut. Considering your pictures the piston, The crank is stock.
    Gone:
    NEPA
    7,051
    Yep,throw the good top end on the good bottom. Your real question being,,is the good runner stroked? Highly unlikely. Measure both engines to certify the crank is the same height. I Always would HIGHLY recommend a hone and fresh rings. Then you are good to go for a long time. I can't say I've ever seen a Honda of any flavor do that with the pin! Very interesting. Post any questions,keep up the good work.
    1,591
    thanks boys. appreciate the input. if i am taking the piston/cylinder/head combo off the runner, should i still hone and get fresh rings? is the thinking that i might as well while I'm in there? makes sense, i guess. how do i determine what rings to get? i suppose i'll be able to tell if its been done once i get in there. who do i get the rings from? honda still sell them?
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    110cc Lifan 70
    82 70
    88 Yamaha BW 80
    84 z50
    Sep 2011
    New Castle, PA
    1,134
    If you can I would make sure the bore and piston are all in spec and get a wiseco. If you want to keep the stock piston and it is good shape, yes hone the cylinder and see if you can still get rings from your local shop. If not there then head to Ebay. There are NOD kits cheap on there all the time.
    Gone:
    Yep, it's one of those "while you're there" kind of things. It would be silly not to hone and ring it. You have to take it apart and see what kind and size of piston you have, then go from there. I'd just be guessing, but I bet Honda still has rings for their pistons. There have been so many 200cc Honda trikes, bikes, and quads made for such a long time.
    Posting at the same time here, but I'd personally take an OEM piston over a Wiseco any day.
    1,591
    "Posting at the same time here, but I'd personally take an OEM piston over a Wiseco any day."
    why is that? and to reiterate, reliable, long term durability is the goal here.
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    110cc Lifan 70
    82 70
    88 Yamaha BW 80
    84 z50
    Oct 2013
    Wherever I May Roam
    3,757
    Reliable long term=OEM.
    NEPA
    7,051
    The piston will be marked on top. A arrow with NO numers will be stock,otherwise it will be stamped with a #,25,50 etc. Either way,you will have the bore of your cylinder measured,that wll dictate the size piston you will use. Then IF the piston in it is still the right size. You will inspect that ,,especially the intake side,for deeper scratches or any cracks. IF all checks out,you get away with rings. For really long term. I would def pop for a new piston and rings. I am assuming here,,most of the pistons on ebay will be sudco or shindy. Both are oe type pistons. And will be the cheapest way out. this will ensure you don't chunk a piston after doing all this work. And you will still be south of $150 w all your parts. You should do a valve job while you're in there too. again,just a good option. We know it runs. but if it has a sharp valve,it won't be long for this world. Only way to know is to look Then put new valve seals in and you are good to go. You will also want to clean the wonderful Honda designed oil spinner /strainer in the crankcase. You will need a special tool for that.
    1,591
    good info all around. thanks. its obama day tomorrow so i should be able to crack into the running engine. i'll have a good idea what i'm dealing with then. i'll post a few updates and then make a decision on what piston to use/buy.
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    110cc Lifan 70
    82 70
    88 Yamaha BW 80
    84 z50
    I have a friend who's a very talented machinist, well two actually if you include Steve as well, but this other guy does boring and sleeving. My first job was working for him in high school. He told me OEM is the way to go and that's all I needed to hear.
    Dec 2013
    Rhode Island
    31
    i have a parts machine 85 200x f/s if any interest i'm in rhode island 1hour south of you
    Actually, where you're talking about this thing being snotty you may want to make sure you don't have a high compression piston.
    1,591
    well, thats sort of the whole question. i'm fairly certain that it will be a completely stock top end going onto this thing. i'll know for sure tomorrow. is there anything i need to watch out for in terms of bottom end mods that may or may not screw me up? also, i'm leaning oem until i hear a good argument otherwise.
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    110cc Lifan 70
    82 70
    88 Yamaha BW 80
    84 z50
    1,591
    Quote Originally Posted by Mudduck View Post
    thanks man. i'm pretty set for now. i'll keep you in mind. you should check out the new england ride thread and come rip sometime.
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    110cc Lifan 70
    82 70
    88 Yamaha BW 80
    84 z50
