Hello kbags948;
Ok, well I do not think your ticking is caused by excessive ignition timing. This is mainly because it would be extremely rare for the bike to start easily AND have some much timing advance that it would cause detonation at IDLE.
That being said, it is a good suggestion to check it since it should be done as part of regular maintenance plus I’m guessing you have no idea what it is currently set at.
I clean off the F mark on the flywheel, put a line of white out on it, then use a timing lite in a dimly lit area to see it easily. If the F mark lites up in the correct location, your timing is fine, if not, set it properly.
The chain, rollers and tensioner are all available new from the site below.
http://partzilla.com might also have them and the price will be cheaper.
If the tensioner roller looks heavily worn I would replace it.
TIMING CHAIN – I would but D. I. D., Wiesco or orig Honda only. There are chains for around 30% less however the chain is a critical part and if it breaks it will make you and your engine very, very, unhappy. It’s also best to replace the timing gears along with the chain, otherwise the chain will wear prematurely.
Tensioner p/n 14500-098-020, $52.00
http://www.cmsnl.com/honda-atc110-19...n_14500096020/
Chain and tensioner
parts fiche.
http://www.cmsnl.com/honda-atc110-19...5.html#results
