Ok, so my atc-90 has been sitting in a field for quite a few years. I would guess at least 10-15. Spark plug is in, and everything was left connected, so no dirt or water got in. Gas tank was drained and cap was on. Oil is full and clean. Motor turns over by hand easily. It ran when it was put away. So what do you think I should do before I try to start it up again. I'm gonna change the oil, and clean the magneto and points and check timing. Pretty much do all the checks and adjustments in the manual. I also rebuilt the carb. What else do you think I could do to get a better idea of how long it might last. Pull the head and look at the cylinder and piston maybe? I don't want to make myself sound like a dumb ass. Should I just overhaul it, or just run it till it blows up? What would you guys do? What should I look at or check?
